Lowered, Sideplated and rear fender cleared
Old Jan 14, 2012 | 05:56 AM
sergeantmajor's Avatar
sergeantmajor
Default Lowered, Sideplated and rear fender cleared
After i picked a couple ideas from some Dyna owners, in here, i decided for the next step:
Got a pair of Tamarack lowering blocks (for 1" lowering) and threw away the relocated turnlights and lowdown plate kit.
Repainted rear fender and went with a sidemount plate with LED light which is, by the way, unexpectedly bright!!!
I just had to fix a custom nut since i didn't want to change the rear wheel axis (which is too short to be used with stock nut and the particular sidemount plate).
The thing is that when installing the Tamaracks, i had to put an extra spacer to the bottom of both shocks,as seen in one picture.
Attached Thumbnails Lowered, Sideplated and rear fender cleared-dsc00230.jpg   Lowered, Sideplated and rear fender cleared-dsc00231.jpg   Lowered, Sideplated and rear fender cleared-dsc00232.jpg   Lowered, Sideplated and rear fender cleared-dsc00233.jpg   Lowered, Sideplated and rear fender cleared-dsc00234.jpg
Old Jan 14, 2012 | 06:51 AM
AFHuey's Avatar
AFHuey
Man, looking at that picture of your rear axle, I am not a fan of your side plate. I see it has a set screw, but you have no threads showing in your axle....looks nice tho...just wouldn't ride it if it that way if it were mine.
Old Jan 14, 2012 | 07:09 AM
sergeantmajor
By "set screw" you mean the small safety screw?
That's instead of the stock safety pin! The nut is not just the "head" you see with the safety screw... It goes all the way through the "ring" of the sidemount plate. So actually this nut it's twice as wide than stock one.
Old Jan 14, 2012 | 08:11 AM
Robbie13's Avatar
Robbie13
LOSER
Looks good!
Old Jan 15, 2012 | 10:27 AM
blueangel73's Avatar
blueangel73
To be on the safe side, I would take the plate mount to a machine shop and get some of the inside axle section (swing arm) side milled down so you can have more axle and nut mating for a more secure mounting. I would hate to be the guy riding or driving behind you I'd that nut comes off.
imboden
Mar 2, 2018 11:32 PM
PFR-Captain
Aug 23, 2015 08:39 PM
Jersey_Marine
Apr 8, 2013 10:09 AM
Coolhawg6622
Touring Parts
Apr 3, 2013 11:42 AM
springer 03
Dec 15, 2010 07:10 AM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
