oil change
I just got done changing all the oil on the Bob and went to tighten up all the drain plugs, checked the manual for the torque values and it looks like the engine oil plug is 14-21ft-lbs while the other 2 are only 3 to 5 ft-lbs, is this right? All three plugs look to be the same? Is this tight enough?
Which manual. Owners or service. I would believe the service manual.
On my Low Rider the engine and trans is 14~21 in lbs. The Primary is 36~60 in lbs. This is the same in both manuals.
Image below is scanned from my 06 Dyna Service Manual.
14-21 FOOT lbs, in all three cases.
Personally, I do not even bother. Snug it then another 1/8 turn or so with a 3/8 breaker bar.
In days gone by, I could do 14 ft lbs with my thumb and index finger.
Point being, 14-21 is not all that damn tight.
You certainly do not want to get too violent and strip it. Bad juju.
mud
