PCV or Power Vision
I heard the company subbed it out and are having a learning curve themselves. i don't know if that's customary or bad. Lots of folks are talking about it, ANY downsides yet?
The original PCs did sit between the O2 sensors and ECU as you describe, pretty similar to how Xieds work. Now though, the PCV is supplied with O2 sensor eliminators and so the sensors don't figure in it all. The PCV doesn't sit between the O2 sensors and the ECU but between the ECU and the injectors. The ECU puts out the information to the injectors with the engine speed and injector opening information, the PC then adjusts the injector opening values (often to richen the mixture) before passing on to the injectors.
Not my preferred solution personally because it removes a set of the bike's major sensors that allow for on-the-fly adjustment for variations in conditions. As well as needing hardware left installed that seems to go wrong fairly often.
Personally, I buy time on a dyno and do my own tuning, so for my Dyna I went with a SEPST. TTS would have been a good alternative.
I'm right at the point of doing this, that's why I'm asking. I get my new full Bassani system any day now. They suggested a PCV, K&N air filter (I like my stock cover's looks) and a Dyno tune. I can see a value in something that doesn't have to stay on the bike and could get damaged or wear out as opposed to hooking up a device only as needed.
Disadvantage of a PCV is that its tuned for the day on the dyno. The O2 sensors are removed and so the self-tuning ability of the bike is disabled and it can't adjust to varying conditions, like the real world has.
The SEPST is Harley's tuning gizmo that lets the bike's tune be adjusted. You can either run with a canned tune and some auto-tuning or else get it set up properly on a dyno for max results. TTS is an alternative doohickey from another maker with a slightly better computer interface for the guy tuning. Neither require anything left on the bike once the tune is set.
The PV is OK and so is the Thundermax. Get one of these with the better O2 sensors and they are supposed to be all singing and dancing alternatives to dyno time. Minor kick in the *** with that is that it aint true.
All those self-tuning tuners (like the Thundermax with auto-tune) give you the air-fuel ratios that their makers think might make your bike (and added bits) run best. However, its just their guess. The bike will make a real good effort at keeping the bike running close to that guess but its not keeping the bike running at the best but at their guess of the best. The only way to know if a bike is performing well is by measuring it on a dyno and adjusting the tune accordingly. Don't listen to any marketing BS that tells you otherwise.
PCV, SEPST, TTS, PV, etc offer a range of canned maps (presets) for different engines, exhausts, etc. Some offer more than others. I'd say PC offer the most and Harley the least. Some of these maps are going to be pretty close to what you need. Others not so great. Depends how fussy you are whether you are happy with a canned map or if you want to get **** and finish the job properly.
The extra I'll get just from the whole exhaust system is substantial and enough for me, all this other stuff is just to make it run "right" per my above goals and I consider, frosting on the cake.
