PCV autotune question
Old Jan 19, 2012 | 08:43 AM
128auto's Avatar
128auto
Default PCV autotune question
Got a PCV installed a while ago, it runs great. I am planning on adding auto tune module and wide band O2s, does it autotune by itself? Do I still need to dyno it for a fuel map? Thanks!
Old Jan 19, 2012 | 10:49 AM
thedonthere's Avatar
thedonthere
Fuel Moto can answer all your questions...........why do you think you want wide band O2 sensors?
Old Jan 19, 2012 | 11:07 AM
128auto's Avatar
128auto
I already talked to Jamie, he said ok, I do want to actually see how you guys use it in real life. I am planning to do a 107ci kit, don't want to spend money and time doing dyno, plus I don't know any good dyno tuning shop in my area, have to DIY. Jamie said they have a canned map for 107 and the autotune should work just fine.
Old Jan 19, 2012 | 11:54 AM
thedonthere
You have one of the best tuners around close to you. The guy that tuned my bike trained him. Doc, who tuned my bike is one of the top 2-3 in the country.
http://www.lonewolfperformance.ca/index.html
Old Jan 19, 2012 | 11:56 AM
128auto's Avatar
128auto
Thanks for the headsup, they are not close at all, I don't live in the island lol, ferry and driving take me half a day to get there.
Old Jan 25, 2012 | 05:47 PM
Seener84's Avatar
Seener84
I am interested in this also; I just ordered a 107" kit from Drago's and want to know if I can get around dyno time if at all possible.
Old Jan 25, 2012 | 07:10 PM
PoCoBob's Avatar
PoCoBob
I've heard good things about Jarz in Abbotsford and I know Denco in Cloverdale put in a dyno but I haven't heard anything about their results.
Old Jan 26, 2012 | 12:21 AM
punkmxcn's Avatar
punkmxcn
I'm wondering the same thing????
Old Jan 26, 2012 | 01:46 AM
Foxster's Avatar
Foxster
I really don't get going to all the cost and expense of a 107" job (+cams?) and then leaving the job unfinished by not getting the fuel set up properly. Are you doing it so you have the number "107" on the side or because you want more power?
All the so-called self-tuner units work the same. The makers produce a map that is their guess at what what will make best power, either by sticking a finger in the air or with some dyno time. You then install that map on a different bike in different conditions and hope its makes best power for you. Chances are it won't. These units do a good job of measuring and keeping the air/fuel ratio where its set at but unless you determine what AFRs make the best power with a dyno then its unlikely that closely controlled AFR is the best tune for power.
Old Jan 30, 2012 | 10:51 AM
Seener84's Avatar
Seener84
Unhappy
I don't know about the original poster; but I am installing the 107", heads, cams etc just to say that I did. Really don't care about better performance or additional power. I think I will get a 107" etched primary cover too, just so everyone can see it.
