Fork Slider Replacement
Old Dec 12, 2006 | 07:16 PM
DGlide04's Avatar
DGlide04
Default Fork Slider Replacement
I'm in the process of taking my front end apart for some winter projects and have a question about the sliders. I'm looking to either replace the stockers with chromed sliders or have the stock sliders sent out to get polished. I found a pair on e-bay from a 2001 Dyna, but my parts manual lists the 04-05 as a different part number. Does anyone know if the sliders from earlier years are interchangable with the 04-05 model years?
I know they changed frames, seats and a lot of other parts in '04 which aren't swappable with the earlier years and in '06 they went with the larger front tubes.
Just checking.
Old Dec 13, 2006 | 12:08 AM
Rambler's Avatar
Rambler
Default RE: Fork Slider Replacement
I believe they changed the axle diameter during 04 05. If the part numbers are different they will not fit.
Old Dec 13, 2006 | 07:03 AM
Naz_Man's Avatar
Naz_Man
You have the 1" axle and as far as I know your stuck with 04-05 parts.... you could just change the wheel bearings to the 3/4 and then you can use the older wheels and sliders but of course you would need a 3/4 axle and spacers.
Old Dec 13, 2006 | 09:32 AM
DGlide04's Avatar
DGlide04
Thanks, that's what I've found out myself. The e-bay sliders won't work and the 06-07 models won't work either due to the larger diameter fork tubes. I think I'll buy an extra pair when I can find them reasonable, just to have since parts for the 04-05 model FXD's seem to be like the redhaired stepchildren of the Dyna line.
Old Dec 13, 2006 | 11:27 AM
ad2's Avatar
ad2
I got the HD chrome sliders for my '04. Looks great, but I wanted to add a fork brace and NO ONE makes a brace that will work with the chrome sliders.
dencor
Feb 10, 2016 09:05 PM
Jackpoticorn
Apr 2, 2015 08:56 PM
HGM
EVO
11
Aug 6, 2012 04:43 AM
Edward Brown
Shovelhead
May 7, 2012 12:24 PM
Dustmaker
Dec 4, 2008 10:24 AM
