F&*^*N Axle
Old Dec 13, 2006 | 12:53 AM
Timmer's Avatar
Timmer
Default F&*^*N Axle
Okay, can someone please tell me what the igit engineer was thinking that made the axle go through the pipe side of HD's? I love to wrench on my stuff but it helps when stuff actually makes sense. Tim
Old Dec 13, 2006 | 12:58 AM
fatboylust's Avatar
fatboylust
Default RE: F&*^*N Axle
Sorry, don't know why, but after the first time you will turn it around so the next time it won't be a problem.
Again, sorry.
FBL
Old Dec 13, 2006 | 01:10 AM
DougsDyna's Avatar
DougsDyna
Make sure you clean the axle up an apply some lithium grease to it when you reinstall it. Mine was abear to get out the first time, at 8000 miles.
DougJ
Old Dec 13, 2006 | 01:14 AM
RudeDog's Avatar
RudeDog
The pipes weren't there when the axel was installed, therefore no problem...
Old Dec 13, 2006 | 02:32 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
He was thinkin........"Frank will never put the pipes on this side"..............
ORIGINAL: TimmerK
Old Dec 13, 2006 | 08:29 AM
RudeDog's Avatar
RudeDog
OR... Maybe they had a temp doing axels those days. They are sometimes hard to train correctly.
Old Dec 13, 2006 | 04:06 PM
duet's Avatar
duet
I read somewhere that it has to do with the possibility of the bearing freezing on the axel, spinning, it then causing the axel to unsrew from the nut. Seems like a stretch to me but I am not a failure analyst.
Instead of taking off the muffler, I tied down the front end, and lifted the back with a jack. Pull the lower shock bolts and you can pull the axel out.
Dan
05 FXDI
Old Dec 13, 2006 | 04:10 PM
Cav's Avatar
Cav
ORIGINAL: duet
Dan
05 FXDI
Which is precisely why reverse threads were invented, but not apparently used in this application.
Weren't reverse threads used on the clutch pack on Shovels?....it's been a long time
Chef 17
May 25, 2018 08:10 PM
evomat
Feb 24, 2016 12:46 AM
Buttz
EVO
22
May 20, 2013 01:46 PM
Failz
Feb 25, 2010 08:57 PM
TIPN8R
Jun 30, 2008 07:24 PM
