Help! Wiring issue regarding rear lights!
Old Jan 29, 2012 | 04:03 PM
DSnoopy's Avatar
DSnoopy
Default Help! Wiring issue regarding rear lights!
So i just got this new set up done that you see on my bike.
Rear signals and brake light are LED. Worked fine in the garage. Worked fine around the block. But now I ride it a few miles today and the rear end lights stop working all together. As such, the signals dont work.
Obviously this was fun to discover while riding next to a cop on colfax. Lol.
Any suggestions???
Old Jan 29, 2012 | 04:06 PM
dpk20x's Avatar
dpk20x
Fuse?
Old Jan 29, 2012 | 04:10 PM
DSnoopy's Avatar
DSnoopy
Lol. ****. I bet you are right. Ill head home with her and check. Wish me luck in the cop harrasment area as they are parked down the block from me right now. Lol
Old Jan 29, 2012 | 04:11 PM
DSnoopy's Avatar
DSnoopy
PS- If it is a fuse does anyone know if i need a bigger one for the LED or something???
Old Jan 29, 2012 | 04:14 PM
Robbie13's Avatar
Robbie13
LOSER
No. LED's pull less current than incadescent.
Old Jan 29, 2012 | 04:50 PM
iDodgimus's Avatar
iDodgimus
could the wiring have touched the wheel at all? happened to me after changing sigs, rubbed right through the wires...
Old Jan 30, 2012 | 08:38 AM
DSnoopy's Avatar
DSnoopy
I check all the wires and did not see any tears. Going to jack it up tonight for a better look.
Got home safe by the way, but did not have enough time to learn the fuses last night. Going to see how it goes tonight.
Any other suggestions welcomed
Old Jan 30, 2012 | 09:10 AM
O.F.'s Avatar
O.F.
Did you loosen any of the fender bolts when you did the install? If so, you may have pinched a wire tightening things back up again. Ask me how I know...
Old Jan 30, 2012 | 11:10 AM
Tundra bob's Avatar
Tundra bob
it should be a 15 amp fuse. It'll be a pain in the a$$, but you'll have to trace your wiring. There's most likely contact somewhere you don't want it to be
Old Jan 30, 2012 | 11:15 AM
Good_Apollo's Avatar
Good_Apollo
Might need a load equalizer
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
