need help!
Old Feb 1, 2012 | 02:44 PM
Napoli's Avatar
Napoli
Default need help!
so somthing is leaking from my heavy breather air intake (from the valve that goes into the engine closest to the front). It only leaks while riding not when parked. It kinda looks like oil and is not alot. Should I be worried?
Old Feb 1, 2012 | 02:50 PM
Dynaglide68's Avatar
Dynaglide68
Old Feb 1, 2012 | 05:53 PM
rooti's Avatar
rooti
Have you been running your oil all the way to the top of the full line on your dip stick.
It's probably hust blow by and won't do it as much if you run between full and add on the dip stick. You can also put on a breather and reroute those hoses that are shooting into the throttle body
Old Feb 1, 2012 | 06:29 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
There was a recent thread about oil being blown out of the HE breathers. I'd also check the oil level when hot. If it's over full you should remove the excess oil or the engine will do it for you.
Old Feb 1, 2012 | 07:10 PM
Napoli's Avatar
Napoli
Awsome...thanx guys
Old Feb 1, 2012 | 07:46 PM
maddghost's Avatar
maddghost
It probably does that if your running hard on it, am i right? All harleys do that. the other guys are right it will do it less with less oil, but it won't harm anything so don't worry about it! Your safe anywhere on the dipstick or so they say , but I prefer to keep my oil level up .
Old Feb 1, 2012 | 08:55 PM
EricInNCa's Avatar
EricInNCa
I never had any leaking with from my heavy breather but recently when I took if off to replace with another A/C, there was this milky looking fluid in the front and valve chambers. Like I said, I never had any leakage but I was a bit surprised to see this stuff...
Attached Thumbnails need help!-ac-grunge-001.jpg   need help!-ac-grunge-006.jpg
Old Feb 2, 2012 | 04:05 AM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Nothing to worry about. Pull out the breather the plugs and put in new O-rings (item # 4 at page 4 of this Instruction Sheet)
Moisture + oil = froth......
Had the same on my FXD2003 dipstick after a long ride in the rain. It will disappear after a 20-25 miles run when the engine (+oil) gets heated up. See this thread:
Frothy mocca brownish colored substance on dipstick
hdng
Engine Mechanical Topics
Apr 14, 2016 12:12 PM
Bassin
EVO
27
Jun 12, 2014 04:28 AM
gnafin
EVO
Mar 12, 2010 04:26 PM
calebrity
Jun 20, 2009 09:33 AM
FXB_Rider
Shovelhead
May 6, 2008 12:28 PM
