How many out there using True Track?
The late-model Dyna frame set-up works pretty good. For 90 percent of H-D riders, this is probably a non-issue.
If you like to push the bike a little, I recommend these stabilizers but they do not 100 percent remove all chassis flex. I used the Sputhe version because I think it looks more oem.
Be careful on the rear installation. It can be a beeyotch and having a helper will be an advantage. Watch out for getting wires and the brakeline pinched too.
Installation was a pain in the a$$, especially having a severe migraine, and on the verge of puking the whole time. I didn't like the way the rear TT went together, but it works. It didn't line up real well, and I had to lightly force the link to mate up with the brackets. I'll post a pic.
You can kind of see that the link isn't parallel to the brackets. I'm not sure if it's an issue, but it sure bugs me, and looks better in the photo, than in person.
I am amazed at the way my bike handles now. Night and day difference! the flat tire feeling in tight turns is gone, Feels much more stable, especially when dodging something like a pothole, and rides straight on my loose gravel road, instead of back and forth like a fish. I'm very pleased so far :-)
I guess the point that really sticks in my mind is if this is such a severe safety issue why no recalls? I received a recall on my truck because a sticker had the towing capacity off by 15 lbs, very minor in my mind. The fix was to replace the sticker.
Are the results of this mod that drastic or one of those things where if I believe in my mind it's better, it must be so? Keep in mind I've never experienced a serve wobble in this bike, and maybe my perspective would change if I had.
My big questions are not do I need the fix, that seems obvious. It is more which one, the True-Track or the Sputhe, and why?
The other thing is I would love to see photos of the Sputhe installed now that I have seen the True-Track.
Bob
I was very surprised that the biggest and most noticeable improvement, was in low speed cornering. I wasn't expecting that. I actually spent 20 minutes today doing slow lock to lock figure-eights, lol. The bike always felt squishy and jiggly before.
