Need input on engine upgrades
Old Feb 11, 2012 | 01:34 PM
SURFOR Chop's Avatar
SURFOR Chop
If you're in Chicagoland area, check out WFO Larry ... ported/polished heads for several forum members including Joe (JRK5892) ... I'd recommend something like his build ... big bore 95" (or 96" 97" or 98" since it should all cost about the same) ... an Andrews TW37 or Woods 6-6 cam and TTS MasterTune EFI system ... you could go to the expense of truing and welding the crank, but you will probably be okay without it ... same with all the business in your primary (compensator, and clutch spring, etc) ... you'll probably be okay without it ... [I have a good friend and long-time Harley wrench who sports a S&S 106" in his 2000 Low Rider ... all stock primary and trans ....]
There is a wealth of TTS tuning available on the Engine/Fuel/Intake/Exhaust section of the Forum ... you can PM a few of the guys with similar configuration and get an almost perfect map for your application ....
Heads, big bore, cams and tuner (stay with your SSS if you want) should cost you around around $2,000 - $2,500 depending on your source for parts (discounts) and yield you 95-105 range for both torque and horsepower ...
R/
'Chop
Old Feb 11, 2012 | 03:41 PM
sharkey's Avatar
sharkey
Everybody has their favorite recipies; mine would be Headquarters 95" with CP pistons and the 0039 cam along with their heads.....
JustinF
The Dyno Room
Feb 25, 2017 09:51 AM
roadkinglobo
2014-2024 Touring Models
22
Mar 20, 2015 08:48 AM
Axegrinder
46
Jan 3, 2015 08:55 AM
USMC_ech110
Sep 10, 2013 01:46 PM
JerryDinMD
May 19, 2012 09:04 PM
