6th gear indicator?
Old Feb 12, 2012 | 02:36 PM
Bagger Jim's Avatar
Bagger Jim
Default 6th gear indicator?
I've got the number 6 on my speedo that lights up when getting into 6th gear (of course). The thing is, it doesn't come on most of the time until I put it under load in top gear, then it will light up. I've contacted the dealer, and the "technicians" have told me several different things (read BS) like "it depends on your speed"... "it takes a few minutes"... "it will be fixed if we dyno the bike and reflash the system"...etc. I would have thought it had a switch in the tranny like the neutral switch. I am going to dig through the service manual and see what I can find, but I thought I'd post here to see if anyone else had the problem.
Old Feb 12, 2012 | 02:38 PM
p51bombay's Avatar
p51bombay
Got a tuner on your bike? If so that is were the problem lies.
Old Feb 12, 2012 | 02:39 PM
TORQUEY's Avatar
TORQUEY
Wow! I love that explanation. Most of these guys are so accomplished they could fool a lie detector.
Old Feb 12, 2012 | 02:41 PM
rbartick's Avatar
rbartick
Mine comes on quickly after I shift to 6th and give it a little throttle.
Old Feb 12, 2012 | 03:00 PM
Reaper_ggy's Avatar
Reaper_ggy
Mine flash randomly once in a while, but dead on when I put it on 6th
Old Feb 12, 2012 | 03:04 PM
soft 02's Avatar
soft 02
Bieng that it is a magnetic pick up sensor you could have some deberis on it skewing the readings.
Old Feb 12, 2012 | 03:08 PM
SIDECAR BOB's Avatar
SIDECAR BOB
all my bikes do that , takes a second or 2 to come on or if you put a little pressure on the shift lever it will sometime turn it off and on , sounds normal, dont know how it reads when the bike in in 6 but it is a bit slow to pick up and has acted the same on all the 6 speeds I've been around
Old Feb 13, 2012 | 04:19 AM
Bagger Jim's Avatar
Bagger Jim
The bike came to me used with SERT. If that's the problem, can it be fixed?
Old Feb 13, 2012 | 04:46 AM
maddghost's Avatar
maddghost
What you r describing sounds normal, unless you have to wait like ten seconds for it to come on. I usually put the engine under load immediately as I shift and yes, it does take like a second and a half to come on. I have never worried about it. Guys who have changed out their power pully no longer get a 6th gear lite.
Old Feb 13, 2012 | 04:55 AM
Fat-Bob-Brad's Avatar
Fat-Bob-Brad
Mine has the odd moment but works fine most of the time i dont know why but it always seems to get worse when i am due to oil change but this could just be me being paranoid LOL
