Powdercoating Turn Signals
Old Feb 13, 2012 | 08:48 PM
SeñorHutch918's Avatar
SeñorHutch918
6th Gear
Default Powdercoating Turn Signals
Is there an easy way to remove the brake and turn signal light housings for powdercoat? The inside isnt wanting to come out and I dont want to damage them. No details other than a drawing in the service manual. Youtube video would be nice!
Old Feb 13, 2012 | 08:55 PM
Stag556's Avatar
Stag556
Not sure which bike your refering to but the bullet turn signals pop out using a flat head screw driver to pry around the edges of the internals. Then you just have to disconnect the wires from the connectors. Pretty simple.
Old Feb 13, 2012 | 09:04 PM
Greatscott's Avatar
Greatscott
I took apart the bullet signals on my Sportster for powder coat. The guts of the signal were just held inside by pressure with a rubber sleeve/gasket. I just carefully pried around the edges with a small flathead until it came loose. The parts were not nearly as fragile as I thought they were once I got them out and looked at them.
I'm sure the Dyna signals are pretty much the same, if not exactly the same.
I actually have a few pictures that I posted in a Sportster forum to help someone else out. I'll put them up here. Maybe they will help.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old Feb 13, 2012 | 09:20 PM
SeñorHutch918
6th Gear
YES! thank you that helps alot. I'll get those apart tomorrow. I thought thats what needed to be done but they werent comming out easily. didnt know if they screwed out or what. THANKS A MIL GUYS
Old Feb 13, 2012 | 11:10 PM
DCLXVI's Avatar
DCLXVI
Compressed air works good too. Put it in where the threads are and it will pop right out.
Old Feb 13, 2012 | 11:20 PM
soft 02's Avatar
soft 02
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Did it the hard way! Use a binder clip on the inside where the bulb goes to pull the guts out. Much easer
Old Feb 14, 2012 | 01:03 AM
Greatscott's Avatar
Greatscott
LOL...there's more than one way to skin a cat. Wasn't nothin hard about the way I did it.
Valleyvets
Jul 31, 2015 02:47 PM
beary
EVO
17
Jul 14, 2015 04:42 PM
Trippster
Dyna Parts
Apr 3, 2015 03:39 PM
Nielsds
Apr 15, 2014 05:58 AM
