Help me diagnose problem...
Old Feb 17, 2012 | 06:31 PM
CM22's Avatar
CM22
Default Help me diagnose problem...
So I just replaced my forcewinder intake with a screamin eagle chrome back plate and K and N filter.
Got on the road today and gunned it...about 3rd gear and I get sprayed with oil like it was shot out of a cannon?
Pulled over and saw that my oil plug had blown off. I walked back down the road and found the plug, set it back on the oil fill (not tight) and started the bike. The plug was jumping up and down like a kid on Christmas morning? Put it on the back of a buddy's truck and brought her home to clean off the oil and diagnose the problem.
Any ideas?
It is a 2000 fxd (carb). I took off the forcewinder with breather setup and out on the screamin eagle in the pic below. Would the breather plugs that comes with the new AC be causing the extra pressure? If so, how do I correct it?
Attached Thumbnails Help me diagnose problem...-forcewinder.jpg   Help me diagnose problem...-screamin-eagle.jpg
Old Feb 17, 2012 | 07:10 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Did you install the the head breather bolts that come with the K&N set up? The hollow bolts and hose to the backing plate are supposed to let the internal pressures and oil vapor go back into the carb. I've the K&N setup for ten years with no problems.
Old Feb 17, 2012 | 08:04 PM
greenstreetbob's Avatar
greenstreetbob
I didn't read your problem because I've been drinking, but ***** are the start of all my problems.
Old Feb 17, 2012 | 08:13 PM
Napoli's Avatar
Napoli
Check your oil level. If you have too much the engine will disperse it if you dont.
Old Feb 17, 2012 | 08:50 PM
CM22's Avatar
CM22
I have the head breather bolts but it came with rubber plugs that cover them. My pic only shows one of them.
Old Feb 19, 2012 | 01:24 AM
greenstreetbob
The rubber hoses should be connected from the bolts(that have holes in the top of them) to the breather.
Old Feb 19, 2012 | 04:32 AM
Foxster's Avatar
Foxster
Just checking... there is a route for the gases from the heads through to the throttle body? Should be through the hollow breather bolts then through those hollow rubber caps to inside the air filter.
Old Feb 19, 2012 | 10:21 AM
Robbie13's Avatar
Robbie13
LOSER
I agree with this problem.
Old Feb 19, 2012 | 09:05 PM
CM22's Avatar
CM22
Fixed it and feel like a moron. Of course I was drinking while putting it on but attached pics of what I did.
Attached Thumbnails Help me diagnose problem...-wrong.jpg   Help me diagnose problem...-right.jpg
Old Feb 19, 2012 | 10:32 PM
onemyndseye's Avatar
onemyndseye
+1 sir.... +1
Jackal1
Oil Archive (no new posts)
Dec 25, 2016 07:38 PM
rcamp01
EVO
15
Aug 7, 2013 05:46 PM
Jojo805
EVO
Jun 4, 2013 11:25 AM
longgreyone
EVO
Aug 25, 2009 08:41 AM
rbabos
Aug 17, 2008 03:51 PM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
