Winter mods-Round 2
Old Feb 28, 2012 | 09:56 AM
07bobber's Avatar
07bobber
Originally Posted by FBinSoCal
Very cool. Looking forward to your report on the rears.
Are you still going to have cohen do the dyno?
I'm heading out there friday to have him install the new pcv and re-dyno it. Just wondering.
BOB,
I will have cohen moto do the dyno but it wont be until later this year when i do cams. I decided againt motor work for winter mods, since suspension is better to do first...
and i will definatly give a good report once my bike is back on the road...
Old Feb 28, 2012 | 12:10 PM
JRK5892's Avatar
JRK5892
hey bud i do not care what ANYONE says.... replace your pulley bolts, do not re use them... replace them! REPLACE THEM!!!! i have had to machine 4 dyna hubs now from people that re use the stock bolts and they sheer them off, myself included... replace them! also run 15 w oil in the forks you will really like how it works with the emulators and keeps things tight so you can tip into turns with no dive but have enough flow to keep the ride soft... on your brakes. pull out the pistons and clean them... pull out the seals and wipe them down with some fresh brake fluid and then brake clean the calipers.... mine where horrible when i did mine last... you have the stuff off you may as well. and bleeding out a single caliper is super easy! fresh fluid never hurts bud... and you know my recomdendation, lyndall gold pads man! no dust... great stopping power and long long life!
glad to finally see a pic of a bike on jack strapped down! hahahaha keep it up!
Old Feb 28, 2012 | 12:13 PM
JRK5892's Avatar
JRK5892
ooh did you drill out your damper holes in the fork dampers at all with the fork emulators? i have not done it myself but i have heard great things about it... there is a big article on it actually... if you can not track it down let me know ill find it for you. (just saw you are using 15w and lyndall pads) hahahaha my bad
Old Feb 28, 2012 | 12:19 PM
JRK5892's Avatar
JRK5892
here ya go
http://forums.streetchopperweb.com/7...ild/index.html
Old Feb 28, 2012 | 12:21 PM
07bobber's Avatar
07bobber
Haha, the tie down is a must for me.
Those bolts are gonna be swapped out for sure, should i just replace them with oem bolts or get some grade 8's?
Also the mc brakes are new to me since this will be my first brake job,
so thanks for the tips.
Old Feb 28, 2012 | 12:22 PM
JRK5892's Avatar
JRK5892
oem are fine they are grade 8
Old Feb 28, 2012 | 12:27 PM
07bobber's Avatar
07bobber
I have a cnc & machine shop here at work so ill get the dampers drilled out by friday when i plan to rebuild the forks...
And thanx for the link..i actually know the guys at race tech in the r&d dept so if i have to i can hit them up and theyll tweek it for me...
When i picked up the kit my buddy mike took me on a tour of the whole factory.....omg that place is awesome...
Old Feb 28, 2012 | 12:32 PM
JRK5892's Avatar
JRK5892
well good get me a hook up on some emulators!
Old Feb 28, 2012 | 01:05 PM
07bobber's Avatar
07bobber
I wish i could, .......i was only able to get $25 off and get some free oil (which is expensive) so im happy i got what i did haha..
Old Feb 29, 2012 | 02:10 AM
fat bastard 68's Avatar
fat bastard 68
Sweeeet! good to know the fit an '07
