thunderheader install tool list
Old Feb 29, 2012 | 11:51 AM
ro9beam2002's Avatar
ro9beam2002
Default thunderheader install tool list
Hey guys, tomorrow night i will be installing the t-header... give me my tool list for the job... should i go get me a swivel head extension..etc..what size..etc.. ... what should i take off to make it easier if anything...... i will have a helper..."heard this makes it easier"
Old Feb 29, 2012 | 05:11 PM
JohnC FXDX's Avatar
JohnC FXDX
Not too much at all. A ratchet with an 8" or longer extension. 1/2" socket, 1/2 open/box wrench and possibly 5/8 socket and wrench for brackets. You will also need some Allen wrenches to mount the new bracket to the transmission. Not sure the exact size though. I just took off my drag pipes and put on a White Brothers 2-1. It didn't come with the bracket so I made my own using the stock one. That is why I'm not sure the size for the trans. I left that bracket on and added to it. I did mine by myself and it only took maybe a half hour if you don't count the fabrication of the new brackets. Nothing else had to be removed either. Pretty straight shot. I did get new gaskets, nuts and flange retainers also. Wanted everything new. Not sure if any anti seize is recommended on the studs, but I didn't use any. I did retorque them after an hour ride though. I also made sure I used lock washers on all of the brackets. Good luck and let's see some pics when done.
Old Feb 29, 2012 | 06:56 PM
macnab_sf's Avatar
macnab_sf
- Recommend a ball-head allen key (1/4") to get at the bolt behind the cable.
- New crush gaskets
- Anti-sieze for your O2 sensors.
- I bought a thin 22mm open-end wrench to turn my sensors. Also bought an O2 sensor socket, but didn't end up using it. (7/8" or 22mm)
- some blue tape to cover engine casings on right to prevent damage
- socket extensions to turn header nuts
[if you dont have 02 sensors, forget that bit ]
Old Feb 29, 2012 | 07:47 PM
ro9beam2002
did you guys use a torque wrench or just tighten them pretty good and re tighten after a few hot/cold runs? no o2 sensors on mine... already bought the screamin eagle gaskets... i already have the chrome flanges and nuts... looks like they can be re-used
Old Feb 29, 2012 | 08:07 PM
ChopperPop's Avatar
ChopperPop
Torque wrench, rode, re-torqued. I also used a large socket to help press the gaskets in evenly.
Old Feb 29, 2012 | 08:43 PM
macnab_sf's Avatar
macnab_sf
I used torque wrench on header bolts. It was less torque than I thought, meaning less than I would have done by hand. You only (on my '06) take them to 60-80 INCH pounds. Just enough to squish the gaskets some.
Old Mar 1, 2012 | 11:10 PM
ro9beam2002
Installed!!! Oh man... the sound is awsome..... sorry for the crappy pics... few beers... and ..oh well.. i will post more if anyone wants to see better ones... taking her out in the morning... the neighbors might not appreciate a ride around the block at 12am... credit goes to the brother-in-law... a helping hand makes it much easier
Attached Thumbnails thunderheader install tool list-photo-16-.jpg   thunderheader install tool list-photo-15-.jpg   thunderheader install tool list-photo-17-.jpg
Old Mar 2, 2012 | 07:42 AM
8541hog's Avatar
8541hog
All you really need is a metric crescent wrench.
Old Mar 2, 2012 | 08:03 AM
JohnC FXDX's Avatar
JohnC FXDX
Looks great Rob, enjoy it. I am so much happier switching over to the 2-1. The drag pipes were just too loud and biting. Not loud in a good way. The 2-1 gives it a much mellower deeper rumble. Still loud but more pleasing. Just sounds more powerful. Not sure if the T-header sounds the same, but I'm sure its not far off. There baffling technique reminds me of the first Flowmaster mufflers for the Mustangs. One of the best sounding exhausts ever. Now go have some fun.
I'm jealous of that near 80* weather you had there yesterday. It was cold and damp here and still is. 33* this morning and did I mention damp. My brothers in Charlotte and he called twice to rub it in yesterday.
Old Mar 2, 2012 | 08:25 AM
ro9beam2002
more pics... this pipes sound awsome... nice loud 30 mile ride this morning to work
Attached Thumbnails thunderheader install tool list-0302120852-1-.jpg   thunderheader install tool list-0302120851.jpg   thunderheader install tool list-0302120923.jpg   thunderheader install tool list-0302120849.jpg
