Need plug for tach
Got the matching tach for my '09 Dyna FXD speedo, got the bracket to mount it and then found that I need the plug that goes into the back of the tach. Apparently HD sells a wiring loom that has tach and speedo plug, but it's a $200.00 piece of wire.
If I can get a pig tail with the right plug, I can splice them over. Anybody know where I could get one. I'll try the Dealer in the am.
Will keep ya' posted. (Posted at V-Twin Forum too)
Thanks
Pat
Here's an image of the back of an FXDL tach.
This tach accepts a 6-way connector (A) in the back (B).
Parts used:
- connector, 6-way - tachometer p/n is 72451-00
- 3 terminals 18-22 ga. -tachometer p/n 72452-00
Here's a link to the instrument wiring diagram for a 2003 Dyna & a link to the main harness from my ***Dyna Models Wiring Diagram Links Index***
Color codes used:
(signal wire) pink runs via pin 7 at main harness to pin 12 at ignition module
(power wire) orange splices to power from instruments fuse
black is ground
