OK so I got a thunderheader,also I have a stage one breather and PCV from fuel moto(great folks) anyway I had decel popping called Fuel Moto got a map fixed that but now its back ,plus at the muffler end collector whatever it is all black like **** so to speak. I am attaching a picture it sux but maybe you can see whats goin on. Is it normal? I have reloaded the map still same sh**
been researching since posting this thread,and found that it is common for chrome thunderheaders turn black at the collector "There are also a lot of people run TH's and love them. It seems that every TH I see suffers from the same problems after a while though. The start to look crappy around the collector and blue, or turn a bit black if they are chrome" I am gonna put new plugs in and reload the map and try again to stop the decel I will let yall know how it turns out
did you check/retighten the exhaust nuts after awhile? your better off dynoing the bike, a map alone gets it close but not close enough.....
I just checked all that, and you are right about dynoing the only problem is the dealer where I live is like way to expensive for me 325.00 hour,maybe one day
decel popping will not cause any damage to your pipeor bike,also when a good amount of soot builds up the popping will go away on it's own! i miss it now that it's gone!
Decel popping may indicate a leak where the pipe meets the cylinder head.
Good place to start. I suggest a dyno tune. Remote tuning is fine if every motor was the same and we all lived at the same elevation but we don't. A dyno tune is custom,so any little difference or variation can be tuned for on the spot.
Amd from what I have read the thunderheader costs a bit of torque on the bottom end. Perhaps a dyno tune can help you there.
