fork bushings
Old Mar 3, 2012 | 12:45 AM
brown dawg's Avatar
brown dawg
Default fork bushings
getting ready to put front forks back together after pc i know i have to replace the seals but should i replace the fork bushings 12000 miles on bike
Old Mar 3, 2012 | 01:23 AM
spankdog's Avatar
spankdog
Might as well. They are relatively cheap and easy to replace. Even if the tephlon coating is intact and no shiny metal is showing through, I would still do it. You already have them apart so now is the time in my opinion.
Old Mar 3, 2012 | 04:35 AM
Navychief's Avatar
Navychief
+1 - Best time to do it.
Old Mar 3, 2012 | 10:25 AM
JRK5892's Avatar
JRK5892
are u talking about the small crush washers if so yes, you can get replacements at ace for like 15c each i have a ton of them in my shop and just swap them when i do fork changes
Old Mar 3, 2012 | 10:28 AM
Inspector 12's Avatar
Inspector 12
When I recently did the for seals on my street bob the teflon was worn through on the bushings on one side. As others have said the bushings are cheap (like 3 to 5 dollars each) so I decided while I was there to do it. As JRK mentions, don't forget new crush washers for under the bolt at the bottom of the tube.
Old Mar 3, 2012 | 10:38 AM
07bobber's Avatar
07bobber
anyone got a part number or description of the crush washers?
Old Mar 3, 2012 | 10:52 AM
p51bombay's Avatar
p51bombay
As you probably know, its part of the rebuild kit, BUT.........I had two kits and one was missing a crush washer, after the office girl questioned whether I bought both kits there (along with $1000 in other parts) they DID have one in stock so they are available - don't know the number though.
Old Mar 3, 2012 | 10:54 AM
ryderbiker's Avatar
ryderbiker
They're copper crush washers. Getting them through HD dealer is a waste of money. Hit up a shop that works in dirt bikes and they will have them in a bunch of sizes. I couldnt find them at a hardware store and HD ordered the wrong thing three times.
Old Mar 3, 2012 | 10:55 AM
p51bombay's Avatar
p51bombay
Cost less than a buck
Old Mar 3, 2012 | 11:09 AM
JRK5892's Avatar
JRK5892
bobber they are just small copper washers that go on the lowers that bolt though the lower and into the fork damper if you dont have that you will have leaky forks
