Stock '12 Exhaust Question(s)
Old Mar 4, 2012 | 10:59 PM
stevieg's Avatar
stevieg
Default Stock '12 Exhaust Question(s)
I just bought an '07 Streetbob that's being shipped that comes with V&H Big Radius 2in2 exhaust. They look great but having had Big Shots on the Heritage in my sigpic I know these are going to be way too loud so I'm looking at options. I like the look of the new Streetbob stock exhaust. I know in the past it was difficult to replace the baffles but has that changed? If so I'd like to get some and replace with some that are nicer sounding. Or...maybe I'll just do what I did with the Heritage. Get a Supertrapp Supermeg. Has anyone looked into or done this?
Old Mar 4, 2012 | 11:14 PM
Fiasco00's Avatar
Fiasco00
I can't answer the baffle question but I can tell you that the O2 sensor bungs may be an issue, HD went to a smaller O2 sensor in 2012.
Old Mar 5, 2012 | 01:35 AM
hellbob37's Avatar
hellbob37
Yes verify that everything will match up if you use an exhaust from 11 and earlier. That's if your not using the O2's.
Old Mar 5, 2012 | 04:37 AM
maddghost's Avatar
maddghost
if you use a pcV you will not need 02 sensors.Unless you use autotune which comes with it's own sensors. But Jamie will already know all of this Stevieg.
Usually the stock baffles are riveted in which you grind or drill out, and later replace with metal screws.
rossWG
Exhaust System Topics
Apr 29, 2018 10:41 AM
caoboii
Jun 19, 2017 11:49 AM
potter
Feb 3, 2013 05:15 PM
sickistrick
Jun 27, 2008 06:43 PM
brandon_77
Dec 23, 2007 04:23 PM
