fork oil ?
Old Mar 5, 2012 | 10:40 AM
brown dawg's Avatar
brown dawg
Default fork oil ?
quick question what do u all recomend harley type e oil or the screamin eagle heavy oil for my forks 09 fxdc
Old Mar 5, 2012 | 10:45 AM
soft 02's Avatar
soft 02
I used SE heave and it greatly improved the fork dive and ride feedback in corners! Depends what you want out of it and how you ride.
Old Mar 5, 2012 | 10:52 AM
JRK5892's Avatar
JRK5892
i think HD fork oil is junk! i use only spectro... for your bike i would run 15w
Old Mar 5, 2012 | 11:03 AM
07bobber's Avatar
07bobber
spectro 15w here also....
Old Mar 5, 2012 | 11:06 AM
soft 02's Avatar
soft 02
I'm about due to change mine again. I think the SE heavy is a 10w. What would be the SE heavy equivalent in spectra?
Old Mar 5, 2012 | 11:28 AM
bikerlaw's Avatar
bikerlaw
Fork oil? What the hell is fork oil for God sakes...... J/K
No matter what brand you choose, go with a heavier oil than stock. You will be very happy you did.
Old Mar 5, 2012 | 11:29 AM
JRK5892's Avatar
JRK5892
heavy weight is 15w... super weight is 20w
Old Mar 5, 2012 | 11:58 AM
O-Town D's Avatar
O-Town D
I switched to the SE oil to tighten up the front end a bit - handling is a bit better and ride is a bit firmer.....
Old Mar 5, 2012 | 12:13 PM
jmeiers's Avatar
jmeiers
SE Heavy here with Progressive drop-in lowering springs. Rides tight and brake dive is VASTLY improved over stock.
Old Mar 5, 2012 | 12:23 PM
rcollinsdad's Avatar
rcollinsdad
Just changed mine this weekend and used the SE heavy. I can definately tell a difference.
