Spring mods have started!
Old Mar 17, 2012 | 09:17 AM
  #41
JRK5892's Avatar
JRK5892
alright! got some work done... replaced the fuel return hose, sure enough had a pin hole in it... from there put in a new fuel filter... then moved on to the pipe... Have to say, it is AWESOME having someone with Tims skill in the shop... Tim is a mad man when it comes to custom pipes, metal, and well to be honest anything he touches... so we got the angle we wanted on the pipe (to allow for a air ride later so i can slam the bike when parked and not worry and then air it up full and not worry about the passanger peg hitting the pipe... also had to make sure the wifes heel would not scratch it while she was on back hahahaha.... got the new angle welded in... then we moved on to the support. after some cutting, welding and bending we where able to get the STOCK bracket from the pipe to work... granted it was cut into a few pieces, but tim was able to weld it all up and bend it to work perfect... around 5am i slapped some gloss black powder on the bracket and we where done! came out PERFECT!!!!
found the hole in the fuel line
replaced the hose with NAPA submersible fuel hose #H209 (cut about 3 inches off it) and used some self tight clamps as Formula suggested in his post
tank all buttoned back up
then moved on to the pipe... first we found our angle so we mounted up the new flange that was cut
then moved on to the bracket, stripped it, and stated to cut and weld
all welded up
all coated and done... insane the amount of work that goes into something so that you can make it so you can not ever see it
how the pipe should sit (sorry to who's pic this was)
how it sits now
Old Mar 17, 2012 | 11:15 AM
  #42
JRK5892's Avatar
JRK5892
ooh ya... whats left: install new oil cooler gasket, install new oil cooler lines, fresh oil, fresh primary/tranny fluid, Tq down clutch case cover, Tq down primary cover (w/ new gasket), final mount pipe... deliver bike to dyno tuner on Tues... HOME STRETCH!
Old Mar 17, 2012 | 11:36 AM
  #43
SteveO-ll's Avatar
SteveO-ll
Lookin Good.............
Old Mar 17, 2012 | 01:14 PM
  #44
ryderbiker's Avatar
ryderbiker
Looking good brother! I thought you were goin I shorten it too?
Old Mar 17, 2012 | 01:17 PM
  #45
JRK5892's Avatar
JRK5892
was going to... but my tuner told me to DEF not go shorter if i want to get the most out of it in HP/TQ on the dyno... the whole reason i am changing the pipe anyway is to get a bit better #'s on the dyno and get it a bit less loud.... so he said do not bob it... so i didnt
Old Mar 17, 2012 | 01:43 PM
  #46
ryderbiker's Avatar
ryderbiker
I'm willing to sacrifice a bit for the look of the pipe I bought. I understand though. I may change my mind when I get my motor done in a month or so.
Old Mar 17, 2012 | 07:59 PM
  #47
nathanw's Avatar
nathanw
Looks about right, half way up the swingarm just before the shock. Any shorter and it may have looked funny.
Old Mar 19, 2012 | 05:38 AM
  #48
darkcvc's Avatar
darkcvc
Looks good.
Old Mar 19, 2012 | 11:41 AM
  #49
JRK5892's Avatar
JRK5892
dont have much to update... other than... i need to find a chromer! hahahaha re bend the middle shiedl to allow for the new angle and the cheap *** chrome spider web'd unreal... what happened to good chrome jobs.... anyway i think i needs to be chrome
Old Mar 19, 2012 | 01:54 PM
  #50
Brewtality's Avatar
Brewtality
i dunno. the chrome really draws your eye to the bend. i'd go black. the pipe bend is such a random part to draw the eye towards.
