Brake pedal sticking
Old Mar 12, 2012 | 08:05 PM
Bigfoots03HD's Avatar
Bigfoots03HD
Question Brake pedal sticking
My rear brake pedal is sticking wondering if anyone has had this problem before and what have you done to fix it?
Old Mar 12, 2012 | 08:12 PM
louisianaSVT2001's Avatar
louisianaSVT2001
Spray some lubricant on the foot brake where it mounts
Old Mar 12, 2012 | 08:23 PM
Bigfoots03HD
What kind of lubricant?
DDuess's Avatar
DDuess
The pedal on my Deuce stuck like that. I discovered that it had been assembled wrong and had no lube on it. There is an o-ring in there and a plastic bushing on the stub the pedal is mounted on. Water got in and rusted it, making the bushing/pedal tight and stick. I had a hard time getting the pedal off, replaced all the soft/hardware with new stuff from the dealer, lubed it with marine grade grease and it has been fine since (2008).
Old Mar 12, 2012 | 09:33 PM
SuperFastGlide's Avatar
SuperFastGlide
wd-40
Old Mar 12, 2012 | 11:32 PM
roneil's Avatar
roneil
i had the same problem and that's what i did and it worked fine.
Old Mar 13, 2012 | 06:10 AM
Bigfoots03HD
Cool I will do that tonight when I get home from work Thanks
Old Mar 15, 2012 | 08:02 PM
Bigfoots03HD
Ok I sprayed the pedal with Wd40 and it's still sticking. Any other suggestions?
Old Mar 15, 2012 | 08:04 PM
SuperFastGlide
un-hook the linkage to confirm its the pedal and not the linkage binding or the master cylinder sticking
Old Mar 15, 2012 | 08:12 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
+1 with Super fast glide.
