06 $treet Bob help
Old Mar 15, 2012 | 12:29 PM
Doc Monty's Avatar
Doc Monty
Stage III
Default 06 $treet Bob help
While riding home after purchasing my 06 street bob from a dealer. The bike started to bog down. I called the dealer who sold me the bike and he advised putting new plugs in... Done, that didn't help. He recommended a mechanic who said it was the 02 senors and stated that a power commandor would do the trick... Nope, didn't work. To make a very long story short, here is what he said he checked. The engine via bore scope, fuel injectors, put on a power commandor,replaced spark plugs, replaced fuel line. He told me he has no idea why it's bogging down. Please help! BTW, the local Harley dealer is booked out until mid April... I know I bought a Lemon, but GA doesn't have a lemon law for motorcycles.
Old Mar 15, 2012 | 12:47 PM
07bobber's Avatar
07bobber
Does it shut off on you? Check the fuel lines (inside tank), clean the throttle body, check plug wires for spark and clean all the sensors and most importantly get a repair manual
Old Mar 15, 2012 | 02:31 PM
jordanball33's Avatar
jordanball33
If its an 06 its probably carbureted.
Old Mar 15, 2012 | 02:39 PM
07bobber's Avatar
07bobber
Not true efi came out in 2002....
Old Mar 15, 2012 | 03:35 PM
Doc Monty's Avatar
Doc Monty
Stage III
07bobber.. thanks for the info. I'll check with the mechanic to see if he did what you mentioned. It never shut off on me, but bogged down enough that I thoght it would. BTW, it is efi, I wish it had a Carb.
Old Mar 15, 2012 | 05:13 PM
dyna rider's Avatar
dyna rider
Default Street Bobs and EFI
All Street Bobs are EFI...that started on 2006. They never made a carbed one.
Old Mar 15, 2012 | 07:54 PM
Karsten's Avatar
Karsten
How many miles? Could be the fuel Pump inside the tank is starting to go bad. The injectors could also be gummed up, add some fuel injector cleaner to the next full tank of gas and get some Octane Booster.
Karsten
Old Mar 15, 2012 | 08:08 PM
missedem's Avatar
missedem
sea foam works great for cleaning injectors. I use it after every winter and it works great. Its probably not a complete solution to your problem but it will help with keeping the injectors clean.
Old Mar 15, 2012 | 08:28 PM
seanarms's Avatar
seanarms
2nd Gear
Doc, what other aftermarket items do you have on the bike besides the power commander or is it completely stock?
Old Mar 15, 2012 | 08:56 PM
dyna rider's Avatar
dyna rider
Default Fuel Hose
You could have chaffed a hole in the fuel line inside the tank. It will not hold good pressure if it has. Or a dirty fuel filter, again inside the tank.
