HELP HELP HELP. No Spark.
Old Mar 20, 2012 | 07:38 PM
bobnehoc's Avatar
bobnehoc
Since you popped a fuse when you initially ran the wires did you also check the breakers as well? The pinched wires you mentioned earlier might have something to do with it as well. They might not appear to be cut but under the insulation they might be damaged. I would either fix the wires or check them for continuity with an ohm meter just to be sure. One last thought, did you cut the wires or did you take the connectors apart. if you cut the wires how did you re attach them? It could be a faulty connection. If you took the connectors apart verify that you put the wires back in the correct locations. Since the bike ran before you did the work it must be related....
Old Mar 20, 2012 | 07:59 PM
Mr.Guns's Avatar
Mr.Guns
Originally Posted by Northern B
x2 .... bumped mine partially off as well when working on the bike .... had me stumped for a few hours, looked like it was seated okay
I actually put my wires on backwards after painting my engine... From that day forward I told myself I wouldn't drink so much when working on the scoot... I might actually adhere to it someday.
Old Mar 22, 2012 | 12:41 PM
Mr.Guns's Avatar
Mr.Guns
Bump for an update! This thing running yet???
Old Apr 28, 2013 | 02:00 AM
SweeetHemi's Avatar
SweeetHemi
BUMP>>>>So what was the cause of the NO SPARK/NO START ??? Going through the same dilemma. Changed bars and now NO SPARK.
ShaneO926
Electrical/Lighting/Alarm
Jun 26, 2016 10:30 AM
Juicer0277
May 17, 2015 09:30 PM
delonick347
General Topics/Tech Tips
May 4, 2014 09:16 AM
megathumpzilla
Dec 11, 2013 02:38 PM
staplek
Feb 13, 2012 03:58 PM
