Stop robbing power from your starter
Old Mar 24, 2012 | 06:04 AM
LarryLives's Avatar
LarryLives
my 2006 FXDWG all shuts off when I hit the start button...
must be prior to 06??
Old Mar 24, 2012 | 06:20 AM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Originally Posted by Foxster
I'd be really interested what the actual wiring changes were.
Looking at Figure B11 (or B10) in the Service Manual...
Did you disconnect the R/BK from the Lights fuse ("O" on 64B) that goes to the common R/BK on the ignition switch (and seal off this wire) and instead run a jumper from that fuse to "T" on the connector to the start relay (62B) and so 87a?
I suppose the only slight downside to this would be that if you stalled the bike at night then the lights would go out when you pressed the starter.
IMO you hit the nail on the head, Foxster.
Here's a 2004 Main Harness Wiring Diagram in which I added this modification.
a. Cut R/BK connection at incoming side of lights fuse (comes from ignition switch in position "ignition").
b. Connect incoming side at lights fuse to start relay pin t (87a).
Red arrows indicate 12 volts flow.
Old Mar 24, 2012 | 09:14 AM
kbootch's Avatar
kbootch
That is exactly what I did with one minor change. Bought a 20 amp relay from from Progressive Wiring.
Old Mar 24, 2012 | 09:52 AM
Austin Dave's Avatar
Austin Dave
Part number for that 20A relay? Addy for that company? There are a few companies with similar name. Thanks
Old Mar 24, 2012 | 10:12 AM
kbootch's Avatar
kbootch
Heading home today. Will post info when I get home.
Old Mar 24, 2012 | 10:51 AM
FXD2003Rider
5 pin 12 volt starter relays & relay base can be bought in Auto parts stores.
Click image to find store info....
Here's some general info on relays:
Old Mar 24, 2012 | 11:05 AM
FXD2003Rider
That's weird...According to the 2006 wiring diagram lights & starter relay feed pins are all connected to R/Bk wire that runs from Ignition pin at Ignition switch.
Perhaps your bike has been modified?
Old Mar 24, 2012 | 02:40 PM
jwright302's Avatar
jwright302
This is great info for me, I have a higher compression engine so any voltage drop I can eliminate helps. Thanks for posting.
Old Mar 24, 2012 | 03:47 PM
BadDwg06's Avatar
BadDwg06
His must be modded...The light on my '06 WG stays on (although dimms really bad) when I start it...But not for long...
OP-Thanks for the tip!
Old Mar 24, 2012 | 04:42 PM
JT-FXDL's Avatar
JT-FXDL
Subscribed... since I just replaced my starter with the higher 1.4 kW hoping for better results. This sounds like a great idea.
