Opinions needed
Old Mar 24, 2012 | 04:46 PM
HYPR's Avatar
HYPR
Default Opinions needed
Ok, here is the deal, I am installing a Road Glide Fairing on my Fat Bob.
I really had no plans on installing an audio system on the bike since if I ever did want music I would just as soon listen to my iPod.
So I am looking at this fairing and it dawned on me, one of the short comings is while wearing a full coverage helmet you need to look down to see the speedometer so why not install a pair of 3"-3.375" guages where the stereo reciever would normally reside.
This could easily be accomplished by fabricating up an aluminum filler plate and drilling the correct holes to accomidate the 2 gauges, one Tach and one Speedometer (and maybe some switches). I could then install a HD filler cover where the stock speedo is on the tank or even fabricate some trick cover.
The speaker openings can be made into additional storage compartments.
The balance of the 4 other openings would house other gauges, Oil Pressure, Voltage, Clock, etc.
Hey it would be different right?
Your thoughts.
Bob
Old Mar 24, 2012 | 05:09 PM
AFMM3's Avatar
AFMM3
I would reconsider installing the stereo in the fairing. It is a lot less trouble to use and most accept the iPod. California law allows only one speaker in your helmet and several (Mass. comes to mind) states will give you a ticket for any speaker in your helmet. If they see a wire, your done.
I have used my helmet intercom to listen to the stereo on my Electra-Glide in the past but it seems to me that anything pushing on your ear starts to really hurt after awhile. I wound up just using the external speakers and am happy with that.
Post pictures either way though, this should be pretty neat to see!
Old Mar 24, 2012 | 05:28 PM
sonnydaze's Avatar
sonnydaze
i guess im not a music guy , i like the sound of the motor , the voices in my head , the sounds of nature . id put gauges in it
Old Mar 24, 2012 | 05:44 PM
xantasm's Avatar
xantasm
My vote would also be stereo but if your not big time into music while riding then what you propose for the fairing sounds cool. Sounds kind of like the dash on one of the old Jeeps where you have the gauges patterned on a flat plate. If your real handy with modding and fabbing your own stuff you could even do lockable covers where the speakers holes are using the material cut out for the openings kind of like the glove box thing on the touring bike lower fairings. You might also consider a double din GPS Nav deck or a dash mount GPS setup where the stereo slot is and even if you still decide on storage vs speakers you would have a nice travel info feature. I know some models will even tell you mph/kph and give you weather and traffic alerts. I agree with AFMM3 that anything in your ears like earbuds or whatever start to annoy the snot out of you on long rides. Soft earplugs in my ears are the only things I can tolerate for long rides.
Old Mar 24, 2012 | 07:37 PM
HYPR's Avatar
HYPR
Thanks guys for the input. All points well taken. I did do a re-check to see if the Road Glide instrument cluster would fit the Fat Bob and nope no way without completely changing everything. Looks like some additional planning is in order here. So here is the rethink, for at very least safety sake if nothing else, I think I will add a second speedometer of 2.625" on the Fairing opposite the 2.125" Tachometer all to compliment the Oil pressure and Voltmeter. I will look again at an audio reciever this time to see if I can find one with a flip out GPS to fit into the OEM audio slot.
Your suggestions and recommendations?
Bob
Old Mar 24, 2012 | 11:44 PM
HYPR's Avatar
HYPR
Well so much for installing a 2.625" Speedometer in one of the gauge openings. Even though the surface would allow something that large the surface is curved so it will not fit without some major modification that would make it look like crap. However I did find a 2.125" Speedo here http://www.speedhut.com/custom_gauge...number-762.htm
They even offer a GPS driven unit so I can run both the tank unit and the fairing mounter unit.
Bob
Old Mar 25, 2012 | 12:20 AM
xantasm's Avatar
xantasm
Some more planning I guess.
Bob
Dakota Digital makes a speedometer for Road Glide fairings but I don't know the specs on sizes and what not but here is the link to their site Dakota Digital dresser & bagger gauges
They are spendy but I've not run across any bad reviews of their products.
Old Mar 25, 2012 | 08:20 AM
AFMM3's Avatar
AFMM3
What all does your fairing have? Did you buy it used, what year is it, is the harness intact, any existing gauges or speakers or lights? Picture from the riding position could be helpful, I haven't studied the Road Glide fairing but I have a touring manual on my computer for reference.
Old Mar 25, 2012 | 08:47 AM
Taddeoeg's Avatar
Taddeoeg
Here's a thought - my Garmin Zumo 550 gps displays speed. I actually found it easier to read/use than the stock speedo on my EG, which isn't a bad layout at all.
Why not use the audio space to mount a gps unit instead of trying to hook up another speedo? I believe you could also patch speakers directly into the garmin so directions come through them (not sure if this would work directly or if the gps uses the stock audio as an amp, but worth looking into. Maybe add a small amp as well)
BTW, I can also upload music to the garmin which would let you ditch the ipod.
Old Mar 25, 2012 | 10:47 AM
HYPR's Avatar
HYPR
I bought the fairing used. The outer is brand new never been installed which I bought used, the inner is used, the windscreen is new, and I bought the headlight assembly from the dealer. I bought the Cyclevision mounting kit to install it. The Raod Glide fairing has remained unchanged since 1998 only the headlight assembly and windscreen have changed. My headlight is a late model 2010-2012 and the windscreen is an aftermarket 12 inch which swoops back almost cafe style.
Regarding the Zumo, yep my brother brags his up big time so it is on the list of considerations.
Just and FYI, the Road Glide Fairing has 4 guage openings an audio opening and 2 speaker openings all which need filling with something.
The only hardware needed it if I install a received I need the mounting frame which I can find easy enough.
Bob
