adding led gauge and led light problem
Old Mar 29, 2012 | 01:14 PM
bbqbrisket's Avatar
bbqbrisket
Default adding led gauge and led light problem
I am trying to add to my 05 Dyna a 12v digital led gauge and a separate led light and am having trying to figure out where to tap
into the power without getting the main wiring harness hot.
Any help would be appreciated.
Old Mar 29, 2012 | 01:54 PM
River_123's Avatar
River_123
So you are looking for a "keyed " power then? Tap off the power wire for your other gauges. Buying a cheap multi meter will help immensely.
Old Mar 29, 2012 | 02:09 PM
bbqbrisket's Avatar
bbqbrisket
Right, "keyed".
What other gauges for example are you referring to?
thanks
R_W_B's Avatar
R_W_B
Originally Posted by bbqbrisket
I am trying to add to my 05 Dyna a 12v digital led gauge and a separate led light and am having trying to figure out where to tap into the power without getting the main wiring harness hot.
bbqbrisket what type of gauge is it ? Or rather more importantly I think you are talking about how to power the illumination of the gauge ?
If so you can just tap into the o/w (orange with white stripe) wire. It's switched at the ignition switch to be on whenever the ignition OR accy is on.
Of course depending on what the gauge is to report on would determine where to hook any other leads. Did it come with a schematic ?
(Update most bikes the o/w is as spoke of above including my 07 Dyna. However you should check your manual schematics to make sure of the color. The wire I speak of is the ACCY circuit fed off the ignition switch and is 15 amp fused thru the ACCY fuse.)
Old Mar 29, 2012 | 02:37 PM
bbqbrisket's Avatar
bbqbrisket
That's right, the illumination. It's 3 wires. One to ground, one to constant power (battery) for the digital (it's a clock) and the last one switched for illuminating.
I will check for the orange and white. I hope it's easy to see under the seat.
Old Mar 29, 2012 | 04:47 PM
R_W_B's Avatar
R_W_B
There should be an o/w on the larger connector (under the seat) going to the rear lighting (thru the fender).
If you are hooking it up under the seat you could also tap into the wires going into Customer Accy plug. It's a 4 wire dephi plug (on mine). It will be empty unless you've already added something that plugs in it. That plug has 2 Orange with red striped wires (on mine), 1 black (grd) wire and 1 r/y wire. Either of the o/r are switched power from the ignition switch. The r/y wire is a switch leg to the rear lighting, don't use it.
However if the clock is going up on the bars or console, there are o/w and black wires under the console plate on the tank also.
Additionally (on mine) there is a brown with gray stripe wire that fused straight from the Battery all the time, you could use for the clock power. This same bn/gy wire feeds out of the fuse box under the seat and also goes to the console so it's available which ever place you decide to use.
clap
Sep 15, 2021 11:25 AM
parag
Electrical/Lighting/Alarm
Jun 9, 2019 09:17 PM
StreetBob07IL
Jun 16, 2009 09:07 AM
PKellyMc
Dec 7, 2008 10:25 AM
myknailsun
Sep 28, 2007 09:57 AM
