Fly By Wire or Push Pull?
Old Apr 2, 2012 | 08:48 PM
emerican19's Avatar
emerican19
Default Fly By Wire or Push Pull?
I'm looking at getting some new grips, I dig these but there's an option for "Fly By Wire" or "Push Pull"- I've got a 2007 Street Bob, which do i get?!
http://avongrips.com/shop/products/C...zed-Grips.html
Old Apr 2, 2012 | 08:53 PM
nevil's Avatar
nevil
Push pull. That refers to the 2 throttle cables. One pulls and the other pushes. It's a mechanical system, fly by wire is electronic.
Old Apr 2, 2012 | 09:56 PM
ghostrider69's Avatar
ghostrider69
I have learned to refrain from speaking my mind on questions like this so I have chosen not to reply.
Old Apr 2, 2012 | 10:10 PM
EricInNCa's Avatar
EricInNCa
Old Apr 2, 2012 | 10:43 PM
emerican19's Avatar
emerican19
Feel free, you have my permission
Old Apr 2, 2012 | 10:44 PM
emerican19's Avatar
emerican19
I figured that, but I thought there was a thin chance that Fly By "wire" referred to the cables. Easy peasy, thanks man.
Old Apr 2, 2012 | 11:16 PM
p51bombay's Avatar
p51bombay
TBW is only on touring models.
Old Apr 2, 2012 | 11:58 PM
DTDK's Avatar
DTDK
fly by wire, is on bikes that do not have the 2 definite cables coming out of the bottom of the right grip. The fly by wire has a sensor that when you twist the throttle, a servo opens and closes your throttle body for you.
Push pull refers to the traditional style of throttle control in which you open and can forcibly close the air passage into an engine (ie your throttle body)
and as others have said, you have push pull not fly by wire
Old Apr 3, 2012 | 09:52 AM
Gaffy52's Avatar
Gaffy52
Push / pull every time man - less to go wrong! Always liked points, carbs and jets for that same reason
Old Mar 11, 2017 | 04:09 PM
kcollins's Avatar
kcollins
so if it says fly by wire, it will not work with push pull? or still will?
