SE Heads
Shiftace ... I got the MCR as well ... not knocking them as much as you, though apparently ...
... I didn't pay retail (don't know that you did) ... they are what they are ...
... but, I am of the opinion they are a definite improvement ... (and in my case, worth it) ...
Also, I readily acknowledge any of a goodly number of head porters who can do as well for the same money (maybe less ... maybe more) than SE ... in my case the MCR have served a purpose ...
The combustion chamber is 81cc so they increase the compression ratio with the abillity to use flat-top pistons ... they do flow considerably better than stock heads ...
... also, you may or may not get equivalent benefit from a independent shop ... as I admit, there are a number of legit operations with excellent results ... but, are the flow bench numbers comparable (a lot of variables ... as with dynos) ... and some shops that might talk a good game but not really know V-Twin motorcycle performance as well as they let on ...
... another fact to acknowledge ... you will end up with a bottleneck in the CFM flow rate somewhere whether it is the air cleaner, throttle body, manifold, port or exhaust ... you may end up 'wasting' the huge flow rate you get from the ported heads ... or, you may actually suffer from too great a flow rate (over the optimal rate) given your displacement and cam characteristics ...
R/
'Chop
p.s. Shiftace ... I mentally have a propensity to transpose the letters "f" and "t" in your forum name ... making me think of Inebriation ... LoL
