HD Fog Lamp Install
Old Dec 29, 2006 | 02:47 AM
Shrug's Avatar
Shrug
Default HD Fog Lamp Install
Got a set of these for Christmas. The destructions call for wiring the lamp switch to the low beam wire in the headlight so that the lights will only work when the low beams are on. I almost always ride with my high beams on during the day and I want to be able to run with the fog lamps. The wiring harness has two 12vdc source lines. One (unswitched) goes to a relay; the other to the lamp switch. I wired the switched wire to the fuse line in the lamp harness. I have to manually kill the lights, even with the power off. I'll dig around and find a switched line to tap into sooner or later.
Pics tomorrow when I have daylight.
Old Dec 29, 2006 | 11:18 AM
oldfrtbkr's Avatar
oldfrtbkr
Default RE: HD Fog Lamp Install
I transfered my fogger from the RG to my Dyna, mounting them on the engine guard. Works great and yes, keyed to only the low beams which works out fine for me. I've found that for my around town riding the low beams plus the foggers are really quite visible during the day.
[IMG]local://upfiles/10968/315C4DD527B542B68F99EFCD40858DEB.jpg[/IMG]
Old Dec 29, 2006 | 12:34 PM
jackyl's Avatar
jackyl
do you have a front pic of the bike? did you internal wire them threw your engine gaurd ?
Old Dec 29, 2006 | 12:48 PM
oldfrtbkr's Avatar
oldfrtbkr
Sorry, no front end pix at this time, just this long shotand with our snow not much of a chance(;=)) Did not go with internal wiring, a lot of work for just looks, imho
[IMG]local://upfiles/10968/C84D90FE093C474AA6EBE7C93476A0D7.jpg[/IMG]
Ricochet59
Jun 16, 2019 02:47 PM
BIGBIRD123
Mar 14, 2013 02:59 PM
Dustmaker
Apr 12, 2012 05:02 PM
jrobinson424
Jul 11, 2010 04:41 PM
rambler43
Sep 20, 2009 06:44 PM
