Look at pic & suggest next mod.
Old Apr 11, 2012 | 10:41 PM
bigdaddy33's Avatar
bigdaddy33
Good looking bike! Ride it for a while before doing major mods. It will give you a chance to decide what you like or don't like and will save you money in the long run.
I'm confused though. If the bike is a carb (as stated in a later post), how did the previous owner change the injectors? Also, what cams did he put in?
Personally, I like mods that improve the performance of the bike. If the bike feels underpowered, I'd look into doing some motor work. At the very least, better pipes, a/c and re-jet the carb.
Lowering the bike may not be the best idea, especially if you plan on doing 2 up riding. Going with a better shocks will improve the bikes performance and ride quality.
Good luck with the bike. Ride safe and have fun.
Originally Posted by 02LowRiderFla
I've had this '02 Low Rider for about a month now and of course I'm ready to start making mods. The original owner changed the wheels, cam and injectors when he bought it and I've already added a Haulen *** sissy pad so the old lady can ride. Here are the mods I'm considering in the future what are your thoughts?
12' Roland Sands Vintage Bars
Remove rear turn signals and install a smoked lens LED taillight that has turn signals build in.
Relocate front turn signals to the forks and change to smoked lens or an altogether different turn signal housing.
Lower the rear an inch with either a kit or new shocks.
Old Apr 12, 2012 | 08:01 AM
02LowRiderFla's Avatar
02LowRiderFla
@BigDaddy33
The previous owner told me about the changes he made when he bought it in 2002. He couldn't remember specifics on the cam. He said he changed the injectors but maybe he meant jets? (I'm a newbie - I'm reading nightly but must admit I do not know a lot about engines). It is definately not fuel injected - has a carb with the enricher ****. I had a harley mechanic ride her and he believes the cam was changed. It has plenty of power and torque (even with 2up) and I'm 6'4" 230lbs. I wil be riding two up for a while 'till the wife gets a bike so I'll take your advice on not lowering. I'm pretty sure forward controls need to be my next move based on my height as I'm only comfortable with my feet on the highway pegs. Thanks for the help!
Old Apr 12, 2012 | 01:43 PM
escherWG's Avatar
escherWG
Originally Posted by Griff08fxdc
Get rid of the reflectors on the fork legs
+1
and loose the football. Cheap easy way is to cut out the inner circle of the football and use that. get a K&N filter too
Old Apr 12, 2012 | 02:44 PM
stevieg's Avatar
stevieg
I'm short so I lower my bikes out of necessity. At your height I'd definitely leave it up. Definitely put some new pipes or slip-ons. A 2in1 looks good and, for the most part, will give you more power than a 2 in 2. Still don't know why people insist on telling others to get rid of the reflectors. Anything that can make you more visibile is good and I don't think they take away from the looks. Until someone mentions it I usually don't notice 'em.
Old Apr 12, 2012 | 05:58 PM
SC-Longhair's Avatar
SC-Longhair
Add an attractive, scantilly-clad model to the photos.
Old Apr 12, 2012 | 09:14 PM
denimbob08's Avatar
denimbob08
i like that idea. maybe several models so we can compare
Old Apr 12, 2012 | 09:38 PM
ryderbiker's Avatar
ryderbiker
Remove the reflectors and stickers on the frame. Heat gun, some leverage, and some adhesive remover is all it takes.
Old Apr 24, 2012 | 11:35 PM
02LowRiderFla
I think the models is a great idea - I'm working on it!
Kquin1987
Feb 22, 2017 10:37 AM
KGlideVivid
Sep 26, 2014 06:23 AM
WARG
Sep 9, 2008 11:15 PM
Bryan53
Feb 10, 2008 02:23 PM
FireHead
Jul 8, 2006 01:13 AM
