Progressive 440 13 inch, belt adjustment?
Old Apr 12, 2012 | 03:17 PM
Lachaine's Avatar
Lachaine
3rd Gear
Default Progressive 440 13 inch, belt adjustment?
Salut
I have a FXDL 2008.
I will receive my progressive 440 13 inch rear shock, and I am looking for the proper procedure to adjust my belt. I know that the new geometry will change the belt tension, so I need a new adjustment for belt deflection. Is there someone that have experience with 13 inch shocks, and know the proper deflection?
Thanks
Salutations du Quebec
Jean-F
Old Apr 12, 2012 | 05:01 PM
dyna rider's Avatar
dyna rider
Default Belt Tension
Just tighten it till you can only twist it about 1/8 of a turn (if the belt is laying flat, like it rides, you can only twist it 45 degrees).
BTW make sure you adjust both sides the same so that the wheel is square to the swingarm.
RandyE01
Milwaukee Eight (M8)
Mar 5, 2018 07:50 PM
LCCXL1200X
Mar 18, 2013 07:01 AM
Voelser
Jul 18, 2012 04:00 PM
Garcia85
Oct 10, 2010 01:50 PM
FXDB
Jul 12, 2008 06:56 PM
