Help
Old Apr 14, 2012 | 11:12 AM
SuperFastGlide's Avatar
SuperFastGlide
thatll work! I prefer mobil 1 20w50 in the motor and primary.., and amsoil severe gear in the tranny,,,
Originally Posted by Dynaglide68
I'm going to use the Harley SAE 20/50 for the motor and Harley Formula + for the Trans and Primary , thanks for the imput
Old Apr 14, 2012 | 07:58 PM
AFMM3's Avatar
AFMM3
If you are curious, H-D Formula+ is also known as Citgo 10W-40 (thank you Hugo Chavez).
Old Apr 14, 2012 | 09:01 PM
GrovenSportster's Avatar
GrovenSportster
Harley oil is provided to Harley by the lowest bidder. Synthetic oil is over rated, the ROI has NOT been proven. That being said, I've used plenty of syn. oil. In short, use quality oils and change per manufacturer's recommendations. Outside of that, unless you have proof from an unbiased source that brand X or type Y is soooo much better than Delo 400 or Castrol in your bike/car/whatever, you have nothing to worry about. I think oil weight is important though. Again, per manfs. recommendation.
PS: These oil threads are great entertainment. No offense to the OP, really.
Old Apr 14, 2012 | 10:46 PM
ynots's Avatar
ynots
Manual doesn't say anything
the manual doesn't talk, you have to read it
Old Apr 14, 2012 | 10:47 PM
lo-rider's Avatar
lo-rider
Does a 2006 Dyna use the same HARLEY OIL SAE 20W50 in all the holes ?
BS. Your owners manual specifies which lubricants you should use.
Old Apr 15, 2012 | 05:49 AM
OldMike's Avatar
OldMike
Using the same oil for the trans and primary does not make sense to me, they are compleatly different applications. Try the search function, oil has been gone over before.
Old Apr 15, 2012 | 05:54 AM
testifer's Avatar
testifer
why is everyone confusing him...the answer is yes, as long as its synthetic. the answer is also yes about its in the manual
Dutch101st
Jul 28, 2014 04:59 PM
Tcobfxdxt
Apr 22, 2014 01:14 PM
screamer56
Mar 31, 2014 01:53 PM
Dguy
Apr 21, 2013 07:13 PM
jrudicel
Oil Archive (no new posts)
Aug 7, 2006 12:58 PM
