gasket for fuel pump module to tank
Old Apr 15, 2012 | 02:50 PM
denimbob08's Avatar
denimbob08
Default gasket for fuel pump module to tank
with the tins being painted this week want to get it back together as soon as possible. the gasket is not reusable and i really dont want to go through the dealer if i dont have to. cannot find it in J & P or anywhere else i look. anybody know where i can get if maybe online?
Old Apr 15, 2012 | 03:38 PM
SuperFastGlide's Avatar
SuperFastGlide
its a dealer item... you can get it cheaper online at either lakeshore, surdyke or ronnies HD
Old Apr 15, 2012 | 04:42 PM
grumpy 1962's Avatar
grumpy 1962
don't forget, the screw's that hold the fuel tank plate down, are a use once throw away item's too.
grumpy.
Old Apr 15, 2012 | 05:31 PM
rdondes's Avatar
rdondes
The top plate gasket is a Harley-Davidson only part. You can walk in and pick it up from your local dealer or order it online from an online dealer such as Surdyke, Latus or Lakeshore. You'll need to replace all of the top plate screws also - they are one time use only.
Old Apr 16, 2012 | 08:13 AM
8541hog's Avatar
8541hog
Unless it has been destroyed you can reuse both the gasket and bolts. I have reused mine several times without a problem.
Passing Lane
Nov 3, 2018 11:59 AM
Panheadpappy
2014-2024 Touring Models
Jan 4, 2018 03:09 PM
SnoRider
Sep 6, 2017 05:26 AM
ultravista
Feb 26, 2017 08:16 PM
fixxr
Feb 8, 2010 09:29 AM
