2012 Dyna Wide Glide
Old Apr 16, 2012 | 08:32 AM
DeerTexas's Avatar
DeerTexas
Default 2012 Dyna Wide Glide
Greetings! I just bought a new ('12) Wide Glide and noticed the front tire is offset from the center of the front fender. I took it to my local dealer who said they looked at another on the show room floor that had the same issue, so they called Harley Corporate. They were told by the Corporate office that this was intentional in order for proper balance. Sounds like a f up to me. Anybody else run across this 'problem'?
Old Apr 16, 2012 | 08:49 AM
SteveO-ll's Avatar
SteveO-ll
It's normal............It is not a problem, I have seen it on all kinds of bikes throughout the years, it is just the way they are designed.
Old Apr 16, 2012 | 09:20 AM
Centerline's Avatar
Centerline
My FatBob, with two brake discs appears perfectly centered. Maybe it could have something to do with balancing/ offsetting the single disc setup on the Wide Glide, tho that is just a guess.
Old Apr 16, 2012 | 10:07 AM
DeerTexas's Avatar
DeerTexas
If it's normal, I guess it's ok. Weird..... but ok. Thanks for the replies.
Old Apr 16, 2012 | 10:16 AM
Dynaglide68's Avatar
Dynaglide68
Old Apr 16, 2012 | 10:43 AM
Cracker1450's Avatar
Cracker1450
I have never noticed that on my 2010, my front tire lines up in the center of the fender.
Old Apr 16, 2012 | 11:12 AM
craigffb's Avatar
craigffb
My bike is like that but it's the rear not the front. Tire is closer to the fender on the right side. It's rides perfectly fine so I'm not too worried about it.
Old Apr 16, 2012 | 11:59 AM
Wideglide103's Avatar
Wideglide103
Same here, rear tire, but mine is offset more to the left. Hopefully it doesn't effect belt/sprocket alignment!?
Old Apr 16, 2012 | 12:37 PM
pontiac69's Avatar
pontiac69
my front tire is dead center of the fender. sounds like they have the wrong spacers on the wheel if the wheel is offset of the fender. pics would be great. here is a pic. crappy pic but you can see its dead center. i even measured with a tape measure.
Old Apr 16, 2012 | 03:49 PM
MX888's Avatar
MX888
I have a 2011 wide glide and mine is centered. Sounds weird to me.
