Dummy gas cap removal
Old Apr 17, 2012 | 06:43 PM
hart11b's Avatar
hart11b
Default Dummy gas cap removal
Does anyone know how to remove the dummy has cap without removing the wire from the tank?
I'm putting in RSD gas caps and this is holding me up. I've seen people say they just removed the circuit, but I can't figure out how to do it.
Old Apr 17, 2012 | 07:22 PM
ct555's Avatar
ct555
Is it the RSD LED dummy cap? I Installed the LED cap a few weeks ago. I can offer some help in that area if your want. Not really sure how to just ditch the circuit. I have read about guys slipping the old circuit under the new cap but no idea on how they went about it.
Old Apr 17, 2012 | 07:26 PM
hart11b's Avatar
hart11b
I don't have the LED. I just want to know how those guys retained all the circuitry.
Old Apr 17, 2012 | 07:32 PM
ct555's Avatar
ct555
Ah sorry man, I'm no help then. If you want to take out the whole wire just shoot me a message.
Old Apr 17, 2012 | 07:36 PM
hart11b's Avatar
hart11b
Thanks. I've got the manual, maybe I'll have to go that route. Hopefully not.
Old Apr 17, 2012 | 10:00 PM
hart11b's Avatar
hart11b
I got it figured out and figured I would post the solution in case anyone needs it in the future.
Step 1: Pull dummy cap straight out to expose in fuel gauge housing.
Step 2: Wires connect the fuel gauge down a tube to the bottom of a tank. We need to remove the circuit and gauge from inside the white housing.
Step 2a: If able, destroy the white housing and remove the circuit in place. Place circuit and exposed fuel gauge in the hole and put on your new dummy cap. Done.
Step 2b: (If you cannot destroy the white housing in place). Cut the three wires near the base of the housing assembly. Set aside the old cap.
Step 3: Pull the fuel gauge wiring from the bottom of tank.
Step 4: Follow that line and disconnect the wires at the quick disconnect (obvious).
Step 5: Destroy the old gas cap. Take care not to damage the internal circuit or fuel gauge. I used a vice, screwdriver and chisel. Remove circuit and fuel gauge.
Step 6: Strip wires to splice, a total of 6 strips.
Step 7: Insert long wire back into the tank, don't reconnect yet to the bike.
Step 8: Splice wires back together and secure with electrical tape.
Step 9: Sit the gauge in the hole and reconnect the wire to the bike. You'll have to go around the forward fuel tank line as the old routing won't work anymore.
Step 10: Insert new dummy cap over gauge and you're done.
A special thanks to thegrants82 and phat413 for the help.
Old Apr 18, 2012 | 08:14 AM
blueangel73's Avatar
blueangel73
When I swap my Gage's out I simply just went under the tank, disconnected the QD and depinned it, pulled the wires with the pins out the top with the gage. I didn't have to cut or splice anything. Some people seem to make more work of things then they need to. I not trying to b a hard *** or mean, I am just saying that if you had taken the time to trace the wiresto under the tank you could have made your work a lot easier.
As far as the dummy cap switch, I haven't seen this and it would be nice if you posted some pics of what you did. Another thing, heat shrink is waaaayyyy better then electrical tape when you have wire that are exposed to the elements.
Fargone11
Softail Parts
Jan 10, 2017 12:06 PM
Fargone11
Dyna Parts
Oct 11, 2015 10:07 PM
Gunny68
General Topics/Tech Tips
Jan 11, 2013 08:16 PM
aframe2
Apr 11, 2009 04:37 PM
jlsporty
Apr 23, 2008 07:14 PM
