56 mpg Dyna explained
Old Apr 18, 2012 | 06:00 PM
craig11dyna's Avatar
craig11dyna
Default 56 mpg Dyna explained
Well I posted a couple weeks ago that I was getting 56 mpg on my 2011 Dyan Super Glide. I started to doubt this could be true when no one else was getting this kind of mileage so I started thinking; is it running to lean? No, I checked the plugs, then I decided to check the odometer and sure enough it is way off. I have the speedo/tach I had installed at my local HD dealer when I had my 500 mile checkup. I checked the miles to my gym on my bike and it was 8.4 then in my wifes car 5.2. So instead of getting 56 mpg I am now in the 40's if not less. Guess I'll be making a trip back to the dealership. If you have this speedometer you may wish to check your odometer.
Here is the speedometer I bought;
Old Apr 18, 2012 | 06:11 PM
128auto's Avatar
128auto
OMFG! I am happy to get 38mpg on my 07 Streetbob, sometimes less. My setup is big sucker 1, PCV and short shot.
Btw nice speedometer! How much?
Old Apr 18, 2012 | 06:14 PM
a10182's Avatar
a10182
ya I like that speedometer looks cool
Old Apr 18, 2012 | 06:23 PM
craig11dyna
$350 installed but not real happy with the erroneous odometer it right now.
Old Apr 18, 2012 | 06:29 PM
craig11dyna
Mystery solved the dealership has the odometers set at Kilometers. Notice the display where I usually have it set on the clock you don't see kph.
Old Apr 18, 2012 | 06:45 PM
thedonthere's Avatar
thedonthere
I regularly get 50 MPG. As a matter of fact I went 177 miles today, filled up when I left and filled up when I got back. 3.48 gal = 50.86 MPG Once, riding with the Florida Crew on the Florida flat land I got 56 one time so it is possible.
Old Apr 18, 2012 | 07:30 PM
TeamMudd's Avatar
TeamMudd
i'm sure the variables of temps, altitude, terrain, ect, have a large variable factor.....
i drive 26 miles one way to work (52miles round trip) the last full week i drove i filled up on the way home. i went 213 miles(that's the farthest i've pushed it with the needle in the red, and the fuel light on), on 4.1 gal 51.9 mpg.... pretty straight shot and not hilly, so i cruise at 60-65 open road. In the colder months i noticed a drop even with non-blend fuel. with the weather temps rising, mpgs getting slightly better.
gas makes a noticeable difference in my bob. if i put cheapo mid grade walmart gas (10% ethanol blend) it will knock back down to 46-47 steady. No ethanol nets better mpg's POINT BLANK! I run mid grade non-blended EVERY chance i get!
i usually keep an eye out for gas between 180-200 miles.
Old Apr 18, 2012 | 07:31 PM
AdrianVall's Avatar
AdrianVall
I was sooooooooooooooooooooo happy for getting 38 MPG the other day. LOL! I would be ecstatic if I ever saw 50 MPG. haha
Old Apr 18, 2012 | 07:39 PM
missedem's Avatar
missedem
I get 38 in the mountains and 40-45 mpg on the highway with straight hwy riding. I was very happy with this result . You should see similar mileage with your bike . I do not baby it at all. In fact I ride 75-80 mph most of the time here in MT.
Old Apr 18, 2012 | 08:03 PM
bsljacques's Avatar
bsljacques
I have the same speedo on mine (I installed myself). I get around 38 to 45 mpg. Depends on home much I turn the loud switch! I have a stage one setup and I am happy with the mpg.
