Holy sprocket
Old Apr 18, 2012 | 09:14 PM
wolfsden_ny2's Avatar
wolfsden_ny2
1st Gear
Exclamation Holy sprocket
I ride an FXDBI or Street bob, yesterday my sprocket bolts backed out and two were sheared before it locked the wheel up. Luckily I was at a light and was just rolling forward. Two years ago it happened for the first time at 75 mph with my wife on the back and all the bolts sheared off and I lost thrust (Thank God that it didn't lock up). Has anyone had this happen to them and have you ever figured out why (other than the obvious, no lock tight).
Old Apr 18, 2012 | 11:01 PM
BadDwg06's Avatar
BadDwg06
Can't speak to bolts backing out except someone didn't use lock tight...bolts shearing off though is pretty common when they are reused instead of replaced.
Old Apr 19, 2012 | 12:17 AM
128auto's Avatar
128auto
Yes, it happened to my last bike, I carry a 5/8 wrench in my toolbag since then, no matter how tight they are, even you use red locktite, still come loose.
READ MY THREAD HERE
Old Apr 19, 2012 | 12:50 AM
hboat's Avatar
hboat
Lots has been written about this issue. If you search "sheared pulley bolts", you'll have plenty of discussion to read;
https://www.hdforums.com/forum/searc...rchid=12586220
I think it's important for all of us to be edumucated about this one. Glad you didn't get locked up, wolfsden.
Old Apr 19, 2012 | 03:20 AM
Krazy8s's Avatar
Krazy8s
I am starting to lose count of the number of people that have had this happen to them.
Kinda gives one a minor permanent pucker factor just waitin' for it to happen!
Old Apr 19, 2012 | 08:09 AM
Prodriverdon's Avatar
Prodriverdon
+1 on the search, It happened to me and MANY others.
Old Apr 19, 2012 | 08:25 AM
128auto's Avatar
128auto
First I thought it was the factory threads, I redid them with helicoil, supposed to be much stronger than stock but its not, still have to tighten up the bolts once in a while. My closest explanation would be coarse thread pitch, if I were the designer, I would make them fine threads instead, lot more strength. Live with it!
Old Apr 19, 2012 | 08:45 AM
wolfsden_ny2
1st Gear
Default Holy sprocket
Wow I can't beleive this is that common. I think that what 128auto said might help but I guess I am just going to have to treat this like an aircraft and do a preflight check every few rides to make sure this doesn't kill me.
Thanks guys
Old Apr 19, 2012 | 09:32 AM
Zig Zag 2010's Avatar
Zig Zag 2010
Ya, preflight check is always a good idea.
Old Apr 19, 2012 | 10:10 AM
EricInNCa's Avatar
EricInNCa
Yeah That!
Plus, I took a sharpie and put a mark on each of the bolt heads that extends onto the pulley. That way I can see at a glance if they are moving. Now if they shear off, that's a different story. I won't see that one coming...
One other thing, you can call me crazy but once I have loctited and torqued the bolts, I don't go back and keep checking them. I feel that once the loctite has cured, I don't want to "break" that seal. That seems to make logic in my mind. Oh well... Cheers.
