wide glide primary cover, pictures
Old Apr 20, 2012 | 07:48 PM
coop creek's Avatar
coop creek
Default wide glide primary cover, pictures
I scratched up the outer primary cover on my 2007 low rider and decided to replace it. I have forward controls and do not need the tunnel for the mid shifter shaft, so I used a wide glide cover for the replacement. I was going to plug up the hole for the shifter shaft in the inner primary cover with a bolt but the parts people and techs at the dealer expressed their concern it might loosen and drop into the case while riding. They gave me the name of a welder in the area, does bikes, hot rods, etc. He was able to weld the opening without taking the inner primary off the bike. I took some pictures:
Picture 1, the primary chain case is open, arrow points to the shifter shaft tunnel which has been welded closed.
Picture 2, close up. He removed the bolt at 7:00 before welding since it has a rubber seal, but I replaced it with a new one anyway.
Picture 3, the inside of the outer primary covers, wide glide on the right
Picture 4, same as above
Picture 5, done.
He also welded closed the tunnel in the original outer primary just in case I decided to use it again, as you can see in the pictures.
Attached Thumbnails wide glide primary cover, pictures-primary-chain-case-001a-medium-.jpg   wide glide primary cover, pictures-primary-chain-case-003-a-medium-.jpg   wide glide primary cover, pictures-primary-chain-case-005-medium-.jpg   wide glide primary cover, pictures-primary-chain-case-008-medium-.jpg   wide glide primary cover, pictures-primary-chain-case-015-medium-.jpg
Old Apr 21, 2012 | 01:47 PM
perryross's Avatar
perryross
When I bought my 07 SB it came with mid controls.
I had them put on forwards.
Looks to me like they just put a cap on the hole?
http://s1125.photobucket.com/albums/l588/PerryJoseph/Street%20Bob/?action=view&current=EngineBridges.jpg
Anyway 18,000 miles with no problems.
Old Apr 21, 2012 | 01:54 PM
brown dawg's Avatar
brown dawg
i would modify that jack and get ride of those lift blocks did mine and its a lot easier jacking bike up
zglide09
Nov 29, 2012 05:18 PM
perryross
Dyna Parts
Jun 15, 2012 02:01 PM
perryross
Jun 15, 2012 09:02 AM
mrsr71
Aug 4, 2007 01:31 PM
Imjonesy
May 7, 2007 08:26 AM
