help with turn signal problem
Old Apr 22, 2012 | 06:11 PM
kmealp's Avatar
kmealp
Default help with turn signal problem
turn bike on and left turn signal is on, hit switch will not turn off, turn bike off turn back on turn signal is off. hit left turn signal and it will not turn on at any time. hit right turn signal both are on hit it both turn off, not all the time some times it only turns on the right one. right works with switch like i said but sometimes both are on using right switch. left never turns on with switch no matter what. is my switch bad or the module or what, i need help
Old Apr 22, 2012 | 09:21 PM
greenstreetbob's Avatar
greenstreetbob
Have you recently changed anything?
Old Apr 23, 2012 | 03:22 AM
kmealp's Avatar
kmealp
I did install a run,turn, stop module but i unpluged it and it still does the same. when you turn the key on and the left one or both turn signals are on the left switch will do nothing but the right one will turn them off if the are both flashing. but if the left one is on all you can do is turn the key off and when you turn it back on it is off.
Old Apr 23, 2012 | 03:43 AM
onemyndseye's Avatar
onemyndseye
almost sounds like the left switch is stuck closed ...?
Old Apr 23, 2012 | 10:10 AM
kmealp's Avatar
kmealp
I was think the switch was bad but needed acouple other oppions.
agreif
Sep 4, 2019 09:43 AM
LoneWoolf
Electrical/Lighting/Alarm
Dec 14, 2015 01:20 PM
mgoldade
Jul 2, 2014 01:02 PM
jnd42697
Apr 12, 2010 12:16 PM
joechief
Aug 11, 2009 10:15 AM
