Please provide some assistance!
Old Apr 24, 2012 | 06:45 PM
denimbob08's Avatar
denimbob08
the reason the tender says its charged is because the battery has a full voltage charge but no longer has the amps to "push" or turn over the starter. all your gauges and lights will work but you cant crank
Old Apr 24, 2012 | 08:19 PM
dbcoooper's Avatar
dbcoooper
Update - Took the battery in and had it tested. Everyone was right it was toast. Bought a deka for $159.00. Installed and the bike fired right up real quick. Thanks everyone.
One last question. After reading a lot of post about the charging system and batteries, I noticed while inspecting my battery cover that there appeared to be some rubbing(fresh rubs where the black paint has been removed) to the inside of the cover exactly where the positive terminal is. Could this have been shorting out anything of would it have to hit the frame some where? Also I put to layers of black electrical tape completely over the positive terminal. Will this suffice?
Thanks again everyone
Dave
Old Apr 25, 2012 | 06:36 PM
dbcoooper's Avatar
dbcoooper
One last question. After reading a lot of post about the charging system and batteries, I noticed while inspecting my battery cover that there appeared to be some rubbing(fresh rubs where the black paint has been removed) to the inside of the cover exactly where the positive terminal is. Could this have been shorting out anything of would it have to hit the frame some where? Also I put two layers of black electrical tape completely over the positive terminal. Will this suffice?
Dave
Thought I would bump this up rather that repost as I think it is dying lol. After searching I cant seem to find any suggestions to my above question.
Thanks again guys.
Dave
Old Apr 25, 2012 | 06:50 PM
jeffrob07's Avatar
jeffrob07
Try splicing tape. It's a little thicker than electrical tape, it's like rubber tape.
Old Apr 26, 2012 | 08:46 AM
dbcoooper's Avatar
dbcoooper
Thank I will look for this tape.
Dave
ride cc
Sep 28, 2020 02:03 AM
High Roller
General Topics/Tech Tips
14
Mar 29, 2016 10:00 PM
TorontoBobber
Dec 28, 2015 06:21 AM
eki912
Mar 7, 2015 09:10 PM
LouisB
Dec 16, 2012 06:37 PM
