Starting Issue
Old Nov 28, 2012 | 10:29 PM
LouisB's Avatar
LouisB
Default Starting Issue
Got a 1996 Sportster that just clicks when I hold the ignition button. Battery reads 11.8v when tested. Obvious problem is the battery, right? Watch the video and tell me what you think. Hoping it's not solenoid related.
Old Nov 28, 2012 | 10:39 PM
jmann8686's Avatar
jmann8686
Sounds like a dead battery to me. Have you tried to charge it and are what happens.
Old Nov 28, 2012 | 10:42 PM
LouisB's Avatar
LouisB
I have a maintainer but after the lights gone green and I unhook the thing the battery reads 11.7v-11.8v
Old Nov 28, 2012 | 11:03 PM
Scuba10jdl's Avatar
Scuba10jdl
Bad battery. Replace before you troubleshoot further. I wouldn't be surprised if that solves your problem.
Old Nov 29, 2012 | 12:54 AM
LouisB's Avatar
LouisB
Just ordered one. I'll be back with an update after it gets here.
Old Nov 29, 2012 | 08:17 AM
jmann8686's Avatar
jmann8686
Agreed
Old Nov 29, 2012 | 08:30 AM
cHarley's Avatar
cHarley
A "no load" battery test is real simple and should always be done before any other test.
- Charge the battery.
- If you've just removed the charger, turn the ignition on for 2-3 seconds and then turn off. This removes any residual (false) over voltage left from the charger.
- If the battery measures < 12.6 volts it's bad, replace it.
Old Nov 29, 2012 | 07:08 PM
LouisB's Avatar
LouisB
Got a new battery today, engine flips and starts if I give it a little gas, but turns off right after I let go of the throttle. Any ideas?
Also I noticed only the rear cylinder block would warm up while the front one stayed cold. Does this mean anything?
Old Nov 30, 2012 | 03:46 AM
Dual-Linkerts's Avatar
Dual-Linkerts
If your bike has been setting for a while and not ridden buy a can of seafoam and add about 4 ounces to some shell 93 octane and change out your old spark plugs with some new ones I gap mine @ 35 then pull your choke out and twist the throttle a few times and start it up.
It will take it a while to warm up then you can ease the choke in and see if it will idle if not then adjust your idle up on the carb a bit.
Once you get it to idle take it out and run the hell out of it so that seafoam can go to work and clean that carb.
Old Nov 30, 2012 | 05:49 AM
cHarley's Avatar
cHarley
Let's back up a bit here. Your OP gives us no history on the bike.
How many miles are on the bike?
Did you just acquire the bike or has it been sitting unused?
How long since the bike was last ridden (when it ran properly)?
When was the bike last properly serviced. (oil, plugs, adjustments, etc)?
