Street Bob Tail Light Replacement Options ?
Old Apr 26, 2012 | 01:31 PM
Basic's Avatar
Basic
I painted mine black and actually really like it. I haven't found a direct replacement that doesn't require rework of the fender.
Old Apr 26, 2012 | 01:38 PM
Divinitus's Avatar
Divinitus
What are some plate light options for the side mount plate? Hd make one?
Old Apr 26, 2012 | 05:45 PM
Divinitus's Avatar
Divinitus
better question, anyone use an emblem, tank or otherwise, to cover the hole left by removing tailight?
Old Apr 26, 2012 | 07:36 PM
blueangel73's Avatar
blueangel73
I have seen people put this over that hole. Part number 91720-02 in case the link doesn't work.
http://www.harley-davidson.com/gma/g...bmLocale=en_US
Old Apr 26, 2012 | 09:20 PM
Divinitus's Avatar
Divinitus
Hmm...If it works and covers the hole that would be cool. Anyone know if the hole edges are roughed up or prone to rust? I would have no problem covering the hole with a medallion like the above, just don't want to have something go wrong with my fender after riding around fior a couple years with the hole covered.
Old Apr 26, 2012 | 09:44 PM
jmeiers's Avatar
jmeiers
Weld all the holes shut and toss the dog ***** and turn signals in the trashcan.
Old Apr 26, 2012 | 09:51 PM
Divinitus's Avatar
Divinitus
Cant do that in MA. My easiest route, if it can be done, is to cover the hole with some sort of emblem and use stock signals for brake/turn signals.
Old Apr 26, 2012 | 09:52 PM
Jay883's Avatar
Jay883
If you don't want to cut the extra wire after the tail light is removed, you may want to deal with those wire first, since the tail light also hide the connectors for the turn signals inside.
The wire hole is stamped and painted, so rust shouldn't be an issue if it's covered properly from under the fender. You can take off the light with T27 torx bit and take a look at the wire harness in the light.
Old Apr 26, 2012 | 11:57 PM
Divinitus's Avatar
Divinitus
So essentially, the tail light housing is hiding a bunch of extra wiring that I would need to store or alter before just throwing a tank emblem or something similar over the tail light hole? I will crawl under the bike when I get home from work and check out the light and maybe check out where I could move the wires to. Thanks!
Old Apr 27, 2012 | 06:49 AM
Robbie13's Avatar
Robbie13
LOSER
I just unplugged mine and took it off. I just taped up the plug from the harness and stored it under my seat. I figure if I ever needed back for whatever reason, it's still there. My rear turn sigs are now just used for brake lights.
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
