Hollow bolt
Old May 9, 2012 | 07:53 PM
Kaycee's Avatar
Kaycee
Default Hollow bolt
Need a hollow bolt to run my rear turn signal wires through ,had to move my sigs. back and don't want to drill another hole.Heard some people use a lamp post stud but they don't make them for the size I need 5/16 x 3". I looked everywhere to get an idea but no luck .any help would be appreciated working on the 05 WG if that helps any
Old May 9, 2012 | 08:01 PM
p51bombay's Avatar
p51bombay
Get the bolts you need from the hardware store - any idiot with a lathe can put a hole in them.
Old May 9, 2012 | 08:29 PM
jeh83's Avatar
jeh83
Harley makes a relocation kit that comes with hollow studs to run wires through that let's u keep signals in factory location when adding detachable equipment to the back.
Old May 9, 2012 | 08:33 PM
SteveO-ll's Avatar
SteveO-ll
Try an electrical supply house.........they even make adapters for different size threaded rods.
Old May 9, 2012 | 08:44 PM
Kaycee's Avatar
Kaycee
I bought a shorter stem looks like the stock stem only shorter.And yes I gave the bolt s to a friend that has a lathe but I may never see those bolts again .I called a bolt supply house today FASTENALL and they were clueless
Old May 9, 2012 | 10:42 PM
j1mmy's Avatar
j1mmy
just put a regular bolt in a vise,and drill a hole through it.. easy enough, i have done it hundreds of times for signals
Old May 9, 2012 | 10:48 PM
soft 02's Avatar
soft 02
Ditto!
fox4
Dec 19, 2009 03:39 PM
medic2931
May 7, 2009 08:26 PM
1Reaper
Nov 9, 2008 08:27 PM
WVleo
Jul 28, 2008 10:13 PM
ckamin
Oct 4, 2006 04:37 PM
