Help! Bolt Size Needed
Old Nov 9, 2008 | 07:05 PM
1Reaper's Avatar
1Reaper
Default Help! Bolt Size Needed
I just got a black wind baffel, went to bolt it up and cant find the correct bolts. I thought it was a m6 .75 but ACE hardware is all out...
Does anyone know the size, and where to get one?
Thanks
Old Nov 9, 2008 | 07:08 PM
gs34doc's Avatar
gs34doc
Big Kahuna HDF Member
1/4 x 20 Run a tap in the holes, to clean the paint and dirt out of the holes, before you put the bolts in.
Old Nov 9, 2008 | 07:12 PM
Bradley Jones's Avatar
Bradley Jones
i dont know the bolt size but if you think its an M6 then gs34doc is probably right with the 1/4 20. when in doubt all the hardware stores around here have a section where you can bring a bolt and thread it in and out on a wall chart to select what size your bolt is. or you can do it the old fashion way and use a set of calipers.
Old Nov 9, 2008 | 07:14 PM
1Reaper's Avatar
1Reaper
Yeah the hole is clean and I tried a 1/4 by 20 and it only turned 1/3 of a turn stopped dead...
Old Nov 9, 2008 | 07:27 PM
BadPiggy's Avatar
BadPiggy
1/4 x 20 x 1/2
The reason it didn't go in...you need to run a tap through the holes.
Excess powdercoating has the holes plugged.
Old Nov 9, 2008 | 07:29 PM
1Reaper's Avatar
1Reaper
Guess I will buy a tap set..
Old Nov 9, 2008 | 07:44 PM
MNPGRider's Avatar
MNPGRider
Here's a cheaper way. Take your 1/4 bolt and "x" the end with a hack saw. You now have a poor man's tap. Run it in a couple turns, back it out, clean out the slots, repeat until threads are clean.
Old Nov 9, 2008 | 08:19 PM
1Reaper's Avatar
1Reaper
MNGP- I like where your head is at, I am going to give that a try tomorrow.
Old Nov 9, 2008 | 08:27 PM
MNPGRider's Avatar
MNPGRider
Reaper, if you have a dremel tool, the ultra thin grinding disk also works really well for slotting a bolt and much easier than a hack saw.
Using either method, put a nut on the bolt first, and after slotting the bolt, turn the nut off. That will clean up the threads on the bolt before you use it on the hole.
Gitarded
May 21, 2019 08:44 AM
jmb79
Nov 21, 2013 06:35 AM
CRocks
Nov 1, 2013 01:46 PM
sioux565
Sep 3, 2011 02:58 PM
anubisss
Dec 11, 2007 10:11 AM
