Stator and voltage regulator change
Old May 11, 2012 | 07:38 PM
Hipolito's Avatar
Hipolito
Default Stator and voltage regulator change
I was told that when i change either the Stator or regulator that i needed to change both otherwise one will burn out the other. Any truth to this and what has been your experience?
Thanks
Hipolito
Old May 11, 2012 | 08:39 PM
EricInNCa's Avatar
EricInNCa
Last fall, I had my stator replaced by the dealer as part of some other warranty work I was having done. They did not replace my voltage regulator. That is my experience...
Old May 12, 2012 | 05:08 AM
1HD1C's Avatar
1HD1C
nearly 2 years ago they replaced my regulator under warranty
they did not replace the stator....
i think mythbusters needs to be called in
Old May 12, 2012 | 08:49 AM
red devil's Avatar
red devil
Not true. I swapped out my stock VR for a chrome one 5yrs ago and haven't had any problems.
Old May 12, 2012 | 10:12 AM
Griff012FLHX's Avatar
Griff012FLHX
I just replaced both..
The reason, i was hoping it was the Reg, it was not so replaced the Stator....
So now I will test the old reg to see if its good, if so, Ill have a spare incase a brother needs one....
Old May 12, 2012 | 10:55 AM
EricInNCa's Avatar
EricInNCa
I'd say Myth "BUSTED"...
Old May 12, 2012 | 12:52 PM
02fx4dude's Avatar
02fx4dude
I think the common assumption is that if one fails, it might cause the other to be questionable. IOW, for example, if the stator fails it may cause an over-current condition which could leave the voltage regulator partially damaged and weakened, or vice-versa. a properly designed regulator would not have that problem. Don't know if the HD regulators are properly designed or not.
Hipolito's Avatar
Hipolito
Thanks Guys, I just thought it was pointless to change both if one part or the other was still working. I was also told that a new part will burn out the old one if you don't change them as a set.
Old May 12, 2012 | 01:17 PM
FXDWG12's Avatar
FXDWG12
If the old part is functioning normally, then there shouldn't be a problem.
Old May 31, 2013 | 07:15 PM
TearlessTom's Avatar
TearlessTom
Electricity is not my strong point. How do you bench test the regulator?
