Switchback pipes
Old May 14, 2012 | 08:35 PM
Pmedic's Avatar
Pmedic
Stage II
Exclamation Switchback pipes
I just bought a switchback and want to change the pipes to a Vance and Hines slip on. I have heard you need to change the air cleaner and dyno the bike and some say you don't. Anybody have experience with this and have an insight. Thanks wes
Old May 14, 2012 | 08:52 PM
leprechaun667's Avatar
leprechaun667
Smile
Hey wes, When you get those pipes; bring them across the street and have that guy help you put them on. EZ install Bring the grips too
Old May 14, 2012 | 08:53 PM
JT-FXDL's Avatar
JT-FXDL
My wife bought a switchback this past spring. I installed the Vance & Hines slip-on because she wanted a better sound than stock. Sounds great! Nice deep rumble without being too loud or obnoxious. And it runs great too. We didn't do air, ECM download nor any tuning. No need to do anything else unless you add stage 1 high flow air kit, in which case you should then do at least the ECM download if not a tuner.
Old May 14, 2012 | 08:55 PM
Pmedic's Avatar
Pmedic
Stage II
Lol thats what I planned on.
Old May 15, 2012 | 12:49 PM
1HD1C's Avatar
1HD1C
just the pipe is no problem, i am running it and a stock crossbones aircleaner on mine
and so long as you dont have to pay THAT guy across the street to do it otherwise it is a whole 10 minute job to swap out the slip on especially on a brand new bike.
just make sure you torque the bolts and clamp(with a torque wrench) to what vance & hines says to and you will be happy
Old May 15, 2012 | 01:36 PM
2011Deluxe's Avatar
2011Deluxe
Actually you can do the pipes and ac without a problem. Some people just dont get it. 07 and later HD's will run just fine with exhaust/air cleaner upgrades and you do not have to do anything to the ECM at all. Closed loop EFI operation uses feedback from the O2 sensor to maintain a constant AFR, even if changes are made to the exhaust and air cleaner.
Old May 15, 2012 | 05:46 PM
1HD1C's Avatar
1HD1C
sorry but i disagree, as they say opinions are like a$$holes and there are many different schools of thought on this subject.
personally i have seen what a lean condition can do to a piston and quite frankly as lean as these things run from the factory its my opinion that the efi cant compensate enough to handle both, so at bare minimum i would run XiEDs if you decide to change both and again its my opinion that its better to be safe than sorry.
Flying Hog
Exhaust System Topics
Jun 17, 2013 03:47 PM
j_howdy
Sep 17, 2010 07:14 PM
Harley Chick 1967
Jan 9, 2009 09:57 PM
kylant
Jul 20, 2007 10:26 AM
harleybiker
Oct 26, 2005 10:10 PM
