Signal relocation question
Old May 19, 2012 | 12:06 PM
ryderbiker's Avatar
ryderbiker
Default Signal relocation question
Has anyone done a front signal relocation, the one that mounts them to the pinch bolt it tube, using bullet type signals? Specifically, signals that use a hollow bolt that the wires run through. I've got to move mine, they're mounted on top of the lower triple tree, after I install the fairing and I don't want to use the stock signals. Any info is appreciated.
Old May 19, 2012 | 05:17 PM
SuperFastGlide's Avatar
SuperFastGlide
well... you cant run a hollow bolt as a triple tree pinch bolt... the wires would have nowhere to go... perhaps a bracket of some sort?
Old May 19, 2012 | 05:32 PM
ryderbiker's Avatar
ryderbiker
Yeah that's what I'm asking. Has anyone done it? I've got mini bullet signals and don't want to go back to the big stock ones or spend $100 on something else.
Old May 19, 2012 | 07:23 PM
JaronB's Avatar
JaronB
I have the drag specialties mounts that go where the pinch bolts are. I opened them, but never used them. If your interested I can give you the part number so you can see if you want them $15 shipped. Otherwise I think there was a mod in the under $50 thread for using parts from the stock mounting hardware.
Old May 19, 2012 | 11:03 PM
ryderbiker's Avatar
ryderbiker
Here's the issue. The kuryakyn mini bullets I have don't have an opening to run the wires through other than the hollow bolt. I've looked at a bunch of relocation kits but all that I've seen have the wires coming out of the signal in a place other than the mounting hole if that makes sense.
Old May 20, 2012 | 07:22 AM
crimson13's Avatar
crimson13
Can you drill a small hole in the mini bullets you have for the wires ? If that not an option, I know you said you didn't wanna spend a 100.0 bucks on nothing new,but have you checked into custom dynamics tru flex I got the 1 1/2 ones for signals for the rear for 34.00 shipped plan on doing the same with the front
http://www.customdynamics.com/trufle...d_lighting.htm
Old May 20, 2012 | 09:56 AM
JaronB's Avatar
JaronB
Heres what I was talking about. You shoud be able to use a hollow bolt of you can find one the right size.
https://www.hdforums.com/forum/dyna-...ml#post2666240
ripto
Jan 21, 2016 06:28 PM
apeluv
Oct 23, 2015 06:35 PM
br549A1
Jan 12, 2014 06:40 PM
jbmunnoch
Dec 9, 2009 12:20 PM
Blathian
Jun 5, 2009 12:20 AM
