Help with Floorboards
Old May 26, 2012 | 03:19 PM
Harley Tim's Avatar
Harley Tim
I went the FLD route with mine. The Wyatts are a little higher and further back. Also you may be looking at exhaust/heat shield clearance issues with either....
I started the "OP" on the FLD boards on a Dyna... here on the forums. I'll look into pulling it up for you if you like.
Oh, and by the way; to answer your question, I really like them! no regrets at all. They look like they should of been there the whole time and, are really comfy for the long haul.
Hope this helps,
Best wishes....Tim(HT)
Here's some pic's http://s1203.photobucket.com/albums/...Tim/?start=all
Here's a thread with a lot of good info;https://www.hdforums.com/forum/dyna-...uperglide.html
Old May 26, 2012 | 07:10 PM
Dunkin's Avatar
Dunkin
6th Gear
Thanks for the pics and tips. I have gone back and forth on boards. Look great
Old May 26, 2012 | 09:11 PM
TGWN's Avatar
TGWN
Originally Posted by SURFOR Chop
Care to share your technique with the forum ...?
After this riding weekend I will take a few pics and figure out how to post them.
Old May 26, 2012 | 10:46 PM
HYPR's Avatar
HYPR
I went with the HD FL boards. I ended up grinding the right rear mount to clear the V&H Staggered pipes. I prefer the position to others I found however on extreme angles in tight curves I have dragged the boards which I have lose so it doesn't effect the handling. I have seen other pans with less of a rectangle shape which would offer more clearance in tight curves.
Bob
HYPR's Avatar
HYPR
Bob
Old May 27, 2012 | 01:38 AM
stevieg's Avatar
stevieg
Romeo had the Wyatts on his Custom and knows a lot about them. Too bad he hasn't chimed in. I'd pm him if I were you. I'm looking to do the same thing but I want the heel-toe shifter when I do it. Being higher and further back wouldn't hurt me. When I finally do it I'll definitely check with him as well as searching for all related threads. Good luck and let us know what you end up doing.
Old May 27, 2012 | 09:54 AM
Romeo's Avatar
Romeo
Originally Posted by AFMM3
The Wyatt reproduction system also has a one piece Heal/Toe shifter that I wouldn't care for myself.
I would probably consider the height of the floorboards over everything else though. If 6 feet tall or taller, I would not even consider the Wyatt System.
I have to agree with AFMM3 here. I'm 5'10, have a 31" inseam and wear a size 10-1/2 to 11 boot depending on brand. If you're taller, the Wyatt's will feel too high and your legs will feel crunched at the knees. If you wear a larger boot, your foot probably won't fit between the pegs of the heel/toe shifter.
As far as fit and finish though, there are no issues with the Wyatt's
-Matt
hollandhunter
Dec 22, 2016 07:56 PM
jcgribks
Apr 17, 2015 11:22 AM
ChromeJunkie
Jul 7, 2009 06:36 AM
DynaNorm
Feb 17, 2009 06:11 PM
Skip
Oct 12, 2007 01:50 PM
