Quick gearing question
Old May 21, 2012 | 10:18 PM
SPECIAL ED's Avatar
SPECIAL ED
Default Quick gearing question
Surely somebody knows the answer to this . I've got an 06 Street Bob it came stock with the 70 tooth rear pulley.Can the front be changed to 30 tooth without replacing the belt? My mechanic says he's pretty confident he can do 31 but not sure about 30.
Old May 22, 2012 | 01:55 AM
hboat's Avatar
hboat
From the Andrews site;
http://www.andrewsproducts.com/PDF_f...lleys-pg29.pdf
Bottom of the page... Every tooth reduction on the primary sprocket requires 1/8th " adjustment of the axle slider.
Do you have that much room?
Old May 22, 2012 | 10:31 AM
JRK5892's Avatar
JRK5892
yes sir no problem at all man, i run a 30/70 on mine stock belt bud
Old May 22, 2012 | 11:38 AM
nevil's Avatar
nevil
This might be a minor point, but just remember your final drive ratio will change, so your speedo and odometer will not be accurate. Your stock ratio is 2.1875 and with the 30 it will be 2.333.
theduroche
Jul 9, 2015 11:13 AM
nyokie
EVO
45
May 25, 2015 10:05 AM
cacasal
Mar 14, 2012 12:18 PM
Temple
Sep 15, 2011 07:13 PM
FAFHD
Nov 11, 2009 09:46 PM
